Sunbeam 701 Humidifier Logo
Anonymous Posted on Dec 08, 2007
Working, but not blowing mist.
I've had this for a month and it stopped blowing mist. It ran completely dry last night and I cleaned out the reservoir with the brush and rinsed with warm water from the vegetable sprayer in the kitchen. Now when I turn it on, the fan blows air but there is no mist. Help!
  • 5 more comments
  • bubbaorion Jan 23, 2008
    blows air but no mist. water level remains same.
  • Anonymous Jan 25, 2008
    Same as the other two.
  • Anonymous Jan 26, 2008
    Didn't run dry just stopped vaporizing water. Fan works OK
  • Anonymous Jan 30, 2008
    I am having the same problem
  • Anonymous Mar 16, 2008
    Having the same problem too....
  • TJ777 Feb 01, 2009
    It was so odd that after just few uses, the humidifier stopped working. I had cleaned it and was so frustrated that it wasn't working... 11:00 at night, grandchild staying over who started coughing in her sleep... you know the DEAL!!!! The fan was blowing really well--- no mist in sight! I followed the solution here and I did get it to work (Yes!). I do have to add that it was very hard to get the base (grey part) off. But it worked. Thank you and to this site also. Just shows what a concerned Nana and the Internet can do... LOL!
  • jkctlc Feb 04, 2009
    I am having the same issue fan working, no mist, water level the same.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
17339
Points
I think I found the problem.
unplug humidifer, remove top tank, empty all water out of base. dry off.
turn unit upside down.
unscrew five visible screws.
use a screw driver to pull off the black foam foot pads. you will find more screws there.
pull off the base.
look next to the fan, you will see a metal "tower" going up into the reservoir. Is it dirty such as white chalky substance on it? Clean it with cotton swabs. Clean the fan while your at it if needed.
You will see a small gray box with two metal tabs twisted. Untwist them and pull off the top.
On that metal "tower" you will see a small black chip connected to the circuit board where you just removed the metal top. Does black chip have black marks on the circuit board? Mine does. I suspect the "tower" which draws heat from this black chip was no longer able to cool because of the white chalk buildup on the tower, furthermore, the chip became too hot and caused the black chip to overheat (again black marks on the circuit board).
The chip has on it "FTR 02N" and a "54F" at the bottom. I tried doing some basic searching on internet to see if it could be replaced, but didn't find anything.
For those who don't have this problem yet, just keep that metal cooling tower clean.
  • xx123 nn
    xx123 nn Dec 18, 2022
    So what is the solution at the end of this long analysis?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
17882
Points
FTR 02N is simply a high frequency transistor. Try to replace it to another type. I have seen FTR 02N in my ultrasonic nebuliser (it's now working.
I think ideal solution is replace all generator circuit. connect a 5 Ohm resistor parallel to the piezoelectric us emitter. Then find simple circuit of negative differential resistor, connect it in series with the emitter to adjustable power supply, then adjust voltage for maximum generating.
  • 2 more comments
  • Anonymous Apr 06, 2008
    Yahoo!
    I've found a circuit for the transducer!
    Here:http://www.fujicera.co.jp/product/e/03/0...
    And here:
    http://www.ee.washington.edu/circuit_arc...
    FTR 02N can be replaced with 2SC4153!
    2SC4153 is specified for this application.
  • Anonymous Apr 09, 2008
    I assembled one of the upper circuits and i can say: it works.
    I used a transistor from some office technics D1762.
    You can replace it with any high-frequency(fT~50-100 MHz) transistor.
  • Russ JD
    Russ JD Dec 18, 2012
    How about Radio Shack - TIP31 NPN Transistor or TIP120 NPN-D Transistor or NTE2633 - T-NPN SI High-Frequency Video Driver
1helpful
Tank is full, but after a few minutes why does it stop and the 'Tank Empty' light comes on?
Reset light comes on, unit stops operating when tank is full ...
www.fixya.com/support/t384577-reset_light_comes_unit_stops_operating
Feb 6, 2008 - Question about Vicks Warm Mist V745A 1 Gallon Humidifier ... Tank is full. ... for about another 5 minutes when the unit stops, reset light comes on etc. ...the humidifier since the reset light keeps going on immediately after I turn ... water in the tank because of course, the heater is on, but no water is getting ...
How to Fix a Humidifier ' HomeTips
www.hometips.com/repair-fix/humidifier-doesnt-work.html
Jan 17, 2016 • Humidifiers
My Sunbeam 705 Humidifier shut down.
Generally a shut down is due to an empty water container or the float valve. If you have a can of compressed air, you can blow dry the integral ports and perhaps free up any contamination that has caused the unit to shut down.
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
My humidifier which is suppose to mist seems to only have the fan blowing. No mist. Lost the manuel and the machine was purchased in feb of 11. What is the solution?
It may have a scale and calcium build up. Particularly, if you use well water.
To clean it, unplug the unit and empty in water that is in the tank. Mix a 50/50 solution of White Vinegar and Bottled Distilled Water (enough to fill the tank. Pour the solution in the tank and allow it to set for 2 hours. Then turn the humidifier ON and place you hand in front of the misting nozzle , to feel if it's working. If it is, allow it to run until the tank is 3/4's empty, Empty te tank of the remaining solution and refill the tank with more Bottled Distilled Water and run for an hour. This will flush the 50/50 solution out of the system. It it wasn't working when you first tested it, allow it to set over night and try again the next morning.
In the future, use Bottled Distilled Water rather than tap water.
95% of the time, this will solve the problem. I hope this helped you. Please let me know.
It has stopped working. How do I clean it. Can the element be washed with soap?
Best way to clean it is with vinegar, it will break up the mineral deposits I'm sure the element has on it. If it is like mine the element is covered in white scale, and has stopped working. May not be worth the effort though, my element is now completely clean but the unit still auto-shuts off after about 5 min.
2answers
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
6helpful
3answers
Cool Mist Humidifier Filter Drying Out
How long are you going between filter changes?
A filter that stops wicking water up and turns orange/yellow is one full of deposits.
It sounds like you have hard water. How are you filtering this water before you use it? Distilled water is the best.
Replace the filter. They don't last forever. Mine normally last a month to a month and a half.
Good Luck
1helpful
2answers
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
5helpful
4answers
Water on floor around humidifier
I haven't had any problems with my Vicks Cool Mist Humidifier other than the fact that the area surrounding it is slightly wet after operating for a couple of hours....While I understand that I was using this to moisturize the air during a cold, I knew this would happen, because the air in my room is not dry. If the room isn't dry, the mist that it's putting out in to the air has no where to go but surround the humidifier. All I did to stop this was to buy a water proof mat. I suggest you do the same -- Also, in regards to the water smelling -- You should be cleaning out and drying the basin after every use. Water shouldn't smell unless you let it stagnate inside the plastic -- Try running distilled vinegar through the machine for a couple of minutes -- Also, I would use an extension cord and let it run outside so that your house doesnt smell like Vinegar.
Top Sunbeam Humidifiers Experts
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
