20 Most Recent Vicks Cool Mist V400 Humidifier Questions & Answers
2answers
The humidifier leaves a lot of water on floor , is
Hi. It looks like more people is complaining about this. It shouldn't happened but I'm think that this is just a big cons of this unit. Return to the shop and buy another one basing on people reviews or use this unit and some rugs
8/4/2015 10:43:53 AM • Vicks Cool Mist... • Answered on Aug 04, 2015
0answers
Wont blow out mist
it has a quiet operation when you got it brand new did it put out mist
11/2/2012 3:45:52 PM • Vicks Cool Mist... • Answered on Nov 02, 2012
4answers
Water on floor around humidifier
I haven't had any problems with my Vicks Cool Mist Humidifier other than the fact that the area surrounding it is slightly wet after operating for a couple of hours....While I understand that I was using this to moisturize the air during a cold, I knew this would happen, because the air in my room is not dry. If the room isn't dry, the mist that it's putting out in to the air has no where to go but surround the humidifier. All I did to stop this was to buy a water proof mat. I suggest you do the same -- Also, in regards to the water smelling -- You should be cleaning out and drying the basin after every use. Water shouldn't smell unless you let it stagnate inside the plastic -- Try running distilled vinegar through the machine for a couple of minutes -- Also, I would use an extension cord and let it run outside so that your house doesnt smell like Vinegar.
2/15/2011 3:40:05 AM • Vicks Cool Mist... • Answered on Feb 15, 2011
0answers
My vicks cool air humidifier will not turn on
try a different electrical outlet.
11/6/2009 3:10:09 PM • Vicks Cool Mist... • Answered on Nov 06, 2009
Loud noise
Try checking the pick up tube that spins from the motor to the resivoir. If this is not seated properly or off balance even just a bit, it can cause your humidifier to sound like a small waterfall. Hope this helps
9/22/2009 9:32:03 PM • Vicks Cool Mist... • Answered on Sep 22, 2009
I need to replace a part . Where do I go on line
dont shoot the messanger but unfortunalty they are not designed to repair. when they break you need to replace. now a whole house duct mounted is diffrent but on the stand alones thats the deal
9/16/2009 3:25:24 AM • Vicks Cool Mist... • Answered on Sep 16, 2009
Hi, I just recently purchased a Vicks Cool Mist
http://www.filters-now.com/products/uvk.html#UFK04=UVK
here is the website that you need to order the filter. the filter model number is k04. right now i'm seeing the filter as being 5.99 before shipping and handling. if you have any other questions please feel free to let me know.
8/26/2009 8:25:01 PM • Vicks Cool Mist... • Answered on Aug 26, 2009
Vicks 400
YES I DID ICALLED THE # ON THE MACHINE THANK YOU FOR YOUR CONCER LUCY.
1/10/2009 11:18:27 PM • Vicks Cool Mist... • Answered on Jan 10, 2009
Vicks hot steam cord gets really hot
My cord is also getting very hot after being plugged in for just a few minutes. Is there a cause for concern here? It's not even a year old, bought in January of 2022.
8/29/2022 11:38:59 PM • Vicks... • Answered on Aug 29, 2022
2answers
Why does my humidifier make the floor all wet
You may be over filling the unit. Take the refillable water tank out and with the power removed try to remove all the extra water where the tank goes. check for anything that looks cracked inside the unit the best you can. If the tank is seating properly it should not leak. If it is filled properly it should not leak.
2/22/2022 6:21:36 PM • Vicks... • Answered on Feb 22, 2022
3answers
Why Is My Vicks Vaporizer Making Gurgling Sounds?
if possible try and check the lines or hoses that run from the wat er supply to the point where the steam comes out. It is very possible that the lines are clogged with water deposits. Thats why most of the time they suggest that you use distilled water in your vaporizer. hop this helps. Lynn
11/14/2021 11:21:38 PM • Vicks... • Answered on Nov 14, 2021
Can I get a replacement water tank cap for my vicks cool mist humidifier v3100?
Probably. Try the manufacturer or service agent.
12/11/2020 8:04:09 AM • Vicks... • Answered on Dec 11, 2020
Vicks Cool Mist V400 Humidifier Logo
29 questions posted
Top Vicks Humidifiers Experts
Robert
Paul Carew
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Vicks Humidifiers
  • Vicks Humidifiers
Most Popular Question
loud noise
  • Humidifiers
