20 Most Recent Sunbeam Ultrasonic Humidifier Questions & Answers
Sunbeam model 705-000
instruction manual fo a Sunbeam Ultrasonic Humidifier Model 705-000
2/2/2019 12:37:05 AM • Sunbeam... • Answered on Feb 02, 2019
0answers
My humidifier
Be the first to answer 3/3/2018 6:09:02 PM • Sunbeam... • Posted on Mar 03, 2018Be the first to answer
How do i fill the whale sunbeam humidifier?
The part at the bottom of the water tank that lets the water into the base unscrews and that is how you fill the tank. It had me stumped too.
10/20/2014 11:27:52 PM • Sunbeam... • Answered on Oct 20, 2014
0answers
0answers
0answers
Not producing mist
Be the first to answer 12/11/2013 4:01:34 AM • Sunbeam... • Posted on Dec 11, 2013Be the first to answer
0answers
0answers
Can I use distilled water
You most definitely can. In fact it's better than using tap water. As it doesn't have all the minerals and chemicals that tap water has, that cause scaling.
Thanks for choosing FixYa.
9/9/2011 5:01:11 PM • Sunbeam... • Answered on Sep 09, 2011
0answers
0answers
Mist coning out leavs white dust all over wood
More than likely the problem is minerals in the water. Impeller and ultrasonic designs send these minerals into the air. If the water in your area contains a lot of minerals, you will notice them as dust.
I would suggest that if you're using well water, switch to using bottled spring water or bottled distilled water. But you'll need to flush out your humidifier first. Use a 50/50 solution of White Vinegar and water. Fill the tank about half way and run the humidifier until the tank is almost empty. You may want to do this in a garage, if you have access to one, so that the vinegar odor won't remain in the house. Once this has been accomplished, dump out any of the remaining solution and flush the unit again with bottle spring water or distilled water. That should do the trick
Even if you aren't using well water, since your water supply has a high mineral content. I would strongly encourage you to use bottled spring water or distilled water in the future. By the way, a gallon of Distilled Water cost a lot less than bottled spring water. In my area I can get a gallon of distilled water from CVS Pharmacy or Food Lion for about $1.00.
Good luck. Please let me know if this solved your problem.
Rich
2/7/2011 7:35:36 PM • Sunbeam... • Answered on Feb 07, 2011
This is a great humidifier...but it's leaving a
Your water is too hard. Get a water softener or use distilled (not purified) water.
2/6/2011 1:53:32 AM • Sunbeam... • Answered on Feb 06, 2011
Sunbeam Ultrasonic Humidifier Logo
53 questions posted
Top Sunbeam Humidifiers Experts
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
View Most Popular
Sunbeam Humidifiers
  • Sunbeam Humidifiers
Most Popular Question
keep
  • Humidifiers
