Humidifiers Logo
B
Bernie Klein Posted on Dec 17, 2016
Sunbeam swm 2412
Where can I find the instruction manual for a sunbeam humidifier model # SWM 2412
4 Related Answers
Anonymous
  • Posted on Jan 23, 2009
SOURCE: Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
LadyDiFixes
  • Posted on Dec 07, 2010
SOURCE: I have a Sunbeam humidifier
After you lift off the reservoir, there are two grey twist locks (one on the left, one on the right. When you twist these, the bottom can be removed from the unit, which contains the filters.
Anonymous
  • Posted on Dec 12, 2010
SOURCE: How do I change the
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Anonymous
  • 7 Answers
  • Posted on Jan 31, 2011
SOURCE: I need to know how to clean the base of my humidifier.
DAILY MAINTENANCE
Allow to cool before maintenance.
1. Before cleaning, set the control to OFF (0) position and unplug the unit from the electrical outlet.
2. Remove the water tank then unlock the misting chamber by rotating the safety lock towards the front of the unit. Lift mist chamber from the unit's base.
3. Empty water and minerals from the base ond place in the top rack of the dishwasher. This will remove any sediment and dirt that has accumulated in the base.
NOTE: It is imperative that the base is deaned properly. The base is dishwasher safe (top rack ONLY) for easy cleaning.
4. Wipe the heating element dean with a soft doth after it has had a chance to cool.
5. Replace misting chamber and engage safety lock. The Electronic Thermal Control Heating element is lined with a coating that is designed to provide the easiest cleaning and prolong the operating efficiency of the humidifier.
DO NOT use any metal or hard objects to dean the Heating Element. Never use detergents, gasoline,
kerosene, gloss deaner, furniture polish, point thinner or other household solvents to clean any part of the humidifier.
WEEKLY MAINTENANCE
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the trzy by partially filling the base with one 8-oz cup of undiluted white vinegar. Let solution stand 20 minutes, cleaning all interior surfaces with a soft brush. Dampen a doth with undiluted white vinegar and wipe out entire base to remove scale.
3. Rinse with doon worm water to remove scale and the white vinegar solution before beginning to disinfect the tank.
4. Wipe the heating element clean with a soft cloth after it has had chance to cool.
Disinfect tank:
1. Fill tank with 1/2 teaspoon of chlorine bleach and 1/2 gallon (1.91) of water.
2. Let the solution stand for 20 minutes, swishing every few minutes. Wet al surfaces.
3. Empty the tank after 20 minutes, and rinse well with water until tho bleach smell is gone. Dry with a clean cloth or papar towel.
4. Refill the water tank with cool wator; replace the housing and water tank. Repeat All Operating Instructions.
2answers
Need the manual for Sunbeam humidifier swm2311
El manual de instrucciones del humidificador Sunbeam SWM2311 est? disponible para su descarga desde la p?gina web Sunbeam. Para descargar el manual del usuario, vaya a www.sunbeam.com/support/manuals y seleccione la opci?n "Humidificadores". Puedes encontrar el manual de instrucciones del Sunbeam SWM2311 en la lista de descargas disponibles
Sunbeam Humidifier model 700. I need a manual for it please?
Question edited for clarity.
It doesn't appear to be a popular model. It may work better where you live. The Sunbeam sites are country based.
https://www.sunbeam.com/instruction-manuals.html
https://www.google.com/search?q=sunbeam+ultrasonic+humidifier+model+700+manual
2answers
I recently found a Sunbeam humidifier without a manual. 1. What filters go in it? 2. Do you have a manual? I think I'm missing a part to this humidifier. Thanks.
Yes Truly Blessed, we do have all the manuals if you can find the model number on the label. They are all listed here on our website.
Home Comfort ... - Sunbeam Canada Instruction Manuals
https://www.sunbeam.ca > home-comfort > humidifiers
Instruction Manuals for Home Comfort Products, Humidifiers. ... SUL1410-CN - Sunbeam® Ultrasonic Cool Mist Humidifier Instruction Manual EN-FR · 1361-705 ...
You can get filters from us
Humidifier Filters & Accessories: Find your filter ... - Sunbeam
https://www.sunbeam.ca > en_CA > home-comfort > hu...
Find your filter for your Sunbeam® humidifier to keep the air in your house comfortable, water treatment tablets offer a light scent to the mist from your humidifier.
and also from our Amazon resellers
Sunbeam Humidifier Filter - Amazon.ca
https://www.amazon.ca > Sunbeam-Humidifier-Filter
Results 1 - 48 of 849 - IOppWin 6 Pack Humidifier Filters Replacement for''A'' Holmes Filters, Compare to Part # HWF62, HWF62D,Compatible with Sunbeam Cool ...
Sunbeam model 705-000
instruction manual fo a Sunbeam Ultrasonic Humidifier Model 705-000
Faulty water level indicator
It is the reed switch inside the post that the float runs on, it gets corroded and needs to be replaced. It is an easy and cheep fix if you can get the reed switch. I would also suggest adding silicone as the factory seal is poor before you put it back together.
12helpful
2answers
I have a Sunbeam humidifier SCM 2412. What is the filter replacement number? How do you get into this thing to replace it?
21helpful
3answers
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
outlet.
2helpful
Just bought a swm 5251 hunidifier with no manual in the box. what are the buttons on the top for? I don't want to run back to walmart at this time of night and want to use the product. How much water does...
  • There is a knob in the centre, which has positions O (Off), 1 (Low), 2 (High). To the left from the knob there is a yellow light, which is a signal to refill the watertank. The red light to the right from the knob is simply POWER On light.
  • The tank holds aprox. 0.9 gallons (3,35 L) of water. This should last about 8 hours.
  • You can find instruction here http://rapidshare.com/files/445360046/SWM5251-CN_owners_manual.pdf
Top Sunbeam Humidifiers Experts
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
