Sunbeam Ultrasonic Humidifier Logo
A
Anonymous Posted on Jan 16, 2014
COOL MIST CHANGES IN OUTPUT - Sunbeam Ultrasonic Humidifier
Mainstays Cool Mist Humidifier 1 gal MDH-0103JW Low Tank Indicator Auto Off NEW Manual
Here are the instructions for the Mainstays Cool Mist Humidifier 1 gal MDH-0103JW:
  1. Remove the water tank by lifting it straight up and off the base.
  2. Turn the water tank over and remove the tank cap by turning it counterclockwise.
  3. Fill the tank with cool water and replace the cap by turning it clockwise.
  4. Place the tank back onto the base, making sure it is seated securely.
  5. Plug the humidifier into an electrical outlet.
  6. Press the power button to turn on the humidifier. The power light will illuminate.
  7. Press the mist button to select the desired mist output level.
  8. The humidifier will automatically shut off when the water level in the tank is low.
  9. To refill the tank, repeat steps 1-4.
Note: For optimal performance, it is recommended to clean the humidifier weekly. Please refer to the user manual for detailed cleaning instructions.
Nov 06, 2022 • Humidifiers
Have ultrasonic cool mist humidifier.....it is blowing cool air ...but no mist...what could the problem be?
It has a little disk about the size of a dime at the bottom of the well where the mist comes out. That metal disk gathers white scale on it, Clean that off. The best way I have found is with a Waterpik turned all the way up.
Feb 06, 2017 • Humidifiers
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 • Humidifiers
S45U-A Cool Mist. Where can I get instructions?
Cool Mist Humidifier - YouTube
? 4:37
www.youtube.com/watch?v=DVB7Jf1kUj4
Apr 14, 2011 - Uploaded by ricks2516 http://coolmisthumidifierreviews.org Cool mist humidifier reviews showing the features of a cheap humidifier ...
Sep 30, 2015 • Humidifiers
I do not see visible vapor
Apperently, it doesn't produce mist.
From the product page "Provides invisible cool mist for easier breathing with 20 percent quieter operation".
No mist is coming out of it but the green light is on.
Hi Lisa,
  • Check that there is water in the Water Tank.
  •  Make sure that nothing blocks the Mist Output Slots.
  •  Check that the Fan Vent on the bottom of the humidifier is not blocked.
  •  Empty the humidifier and rinse the Water Basin with cool tap water and allow to dry for 15 to 30 minutes before resuming normal operation.
  •  Check for possible mineral deposits on the Water Level Sensor or the Nebulizer.
For more information, check out the owner's manual here. It is truly helpful!
Good Luck!
7helpful
2answers
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
6helpful
2answers
We have a Sunbeam Cool Mist Ultrasonic Humidifier that we bought just over 2 months ago. Up until a couple of days ago, it was producing mist and running just fine. I cleaned it with the brush and got the...
I have this same problem. And cool mist humidifiers DO produce mist. I have had my humidifier for a while now (6 years) and have never had any problems. But after the most recent cleaning, it worked at first, but now seems to not be working anymore... Am also wondering if there is anything I can do to remedy the situation?
Top Sunbeam Humidifiers Experts
Dennis
ADMIN Andrew
ADMIN Andrew
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
