20 Most Recent HP DeskJet F380 All-In-One Printer Questions & Answers
5answers
I have a HP Officejet 6300 and it is showing as Offline
go to control panel, then printers and faxes, then right click on it and click "use printer online"
hope this helps!
4/16/2024 7:34:38 AM • HP DeskJet F380... • Answered on Apr 16, 2024
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
11/26/2021 7:03:53 AM • HP DeskJet F380... • Answered on Nov 26, 2021
13answers
HP Deskjet F380 Drivers
i was in HP tech support supporting AIO printer models, Just click on the link u will get a popup window to download the Driver for ur Printer.
http://snipurl.com/f380_driver_xp
11/6/2021 7:05:39 PM • HP DeskJet F380... • Answered on Nov 06, 2021
2answers
Clean the print head for an HP F380
If the cartridges are new, make sure you removed the, (sometimes clear), tape that the manufacturer places over the shinny metallic ink distribution slots, (shinny objects on the underside of the cartridges, like the previous answers have described). Otherwise, make sure the cartridges are the correct model for your printer, and I use a dab of alcohol on my q-tips to clean off old dried ink from the contacts. The contacts are very obvious once the cartridges are removed. Make sure to unplug the printer once you have removed the cartridges to access the contacts, before cleaning. And be gentle with the contacts, rub gently. And clean the cartridge contacts and ink dispensing slots as well, and gently as well. As previously mentioned, you should get ink on the q-tip when cleaning the ink distribution slots. Three colors, yellow blue and red from the color cartridge and black from the black cartridge. So clean the contacts first, then do the ink dispensers last to avoid adding ink to the contacts with a ink soggy q-tip. Good luck and be gentle.
7/29/2021 7:31:42 AM • HP DeskJet F380... • Answered on Jul 29, 2021
Hi i have a HP
check out the HP website for support HP Deskjet 1050 All in One Printer J410a Troubleshooting
7/25/2021 11:27:57 AM • HP DeskJet F380... • Answered on Jul 25, 2021
I cannot connect wireless to my HP 3520 printer
Please check your wireless connection? are you sure you are typing the correct username and password for your wireless on your printer. if it is still not working fine then you need to call hp tech support at toll free number- 1-800-585-2494 or visit: HP Customer service . hope this will help you better.
7/22/2021 4:49:28 AM • HP DeskJet F380... • Answered on Jul 22, 2021
2answers
HP deskjet D2300 series printer is showing offline .Power is already given to the printer.
check that the printer is turn on, if on turn it off and on again, secondly check by double clicking the printer icon on your pc start bar i,t will open a pop/dialogue box, click on file and see if the offline is tick if so disable the tick.
7/22/2021 4:48:29 AM • HP DeskJet F380... • Answered on Jul 22, 2021
10answers
HP Deskjet F380 All-in-One Compatible with vista
I had the same problem. I could print, but not scan.
However, if you open up Paint and go to file and scan, it will scan your document. For some reason, using the scan button on the printer itself will not work with Vista, but using Paint will. I also heard that using Windows fax and scan will also work.
good luck
7/22/2021 4:30:42 AM • HP DeskJet F380... • Answered on Jul 22, 2021
8answers
Getting "E" error icon with orange light flashing above by ink drop icon
click on start, then click run, type in the word services.msc, you will then get a list of options scroll down the lost to the letter p and find the word print spooler. click print spooler once then in the left corner you will have to options, either to stop or refresh, before doing anything take the usb out of the back of the printer, then click on stop, then click start, then click refresh, after this put your usb back in the printer, and that ''should'' solve the problem. email me if works or does not, thanks
7/22/2021 4:28:30 AM • HP DeskJet F380... • Answered on Jul 22, 2021
3answers
Printer error 0x610000f6 whaat does this mean
This printer model F380 will not show 0x610000f6 error. It means "Ink Delivery System failure". Please confirm your printer model.
7/22/2021 4:27:58 AM • HP DeskJet F380... • Answered on Jul 22, 2021
2answers
Hp deskjet f2280 pinter windows 7 driver free
Hp deskjet f2280 pinter don't install in windows 7. now what can i do ?
7/22/2021 4:23:21 AM • HP DeskJet F380... • Answered on Jul 22, 2021
2answers
MY MAC WONT PRINT
You can call hp tech support toll free number - 1-866-987-2474 and they will give you all information regarding to your printer. for more information you can visit HP Customer service. Hope this will help you better.
2/13/2020 3:06:45 PM • HP DeskJet F380... • Answered on Feb 13, 2020
I need to Install my hp deskjet f4100 printer
Hello there Andoni,
What particular model of the HP F4100 series is your printer? For the F4100 series, you can choose among the installation driver here:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-001&h_lang=en&h_client=s-s-r2515-1&h_cc=ca&h_query=HP+Deskjet+F4100+All-in-One+series
Hope this helps.
12/4/2019 9:55:57 AM • HP DeskJet F380... • Answered on Dec 04, 2019
F380 All-In-One won't print
first of all you need to install the software..these are the steps to install the software please follow the steps below
Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
  9. once the software installation is complete try to print that should work
11/6/2019 6:42:25 AM • HP DeskJet F380... • Answered on Nov 06, 2019
How do I install my HP deskjet 1000 printer without a cd
download driver for your particular operating system https://support.hp.com/us-en/drivers/selfservice/hp-deskjet-1000-printer-series-j110/4066042/model/4066376
9/24/2019 11:09:49 PM • HP DeskJet F380... • Answered on Sep 24, 2019
2answers
How to instal my printer without the cd installer HP Deskjet 1051
8/24/2019 7:14:39 PM • HP DeskJet F380... • Answered on Aug 24, 2019
2answers
LOST MY INSTALLATION CD NEED TO INSTALL MY PRINTER ON MY COMPUTER
To get the drivers select the link below
http://www.siliconguide.com/drivers/device/617/
when you get to this website select right download for your operating system, save file and install, that easy
cheers
Brett.
5/21/2019 8:27:13 AM • HP DeskJet F380... • Answered on May 21, 2019
2answers
Go to hp.com, product support, download driver, type in your model number and go.
5/7/2019 9:59:49 AM • HP DeskJet F380... • Answered on May 07, 2019
2answers
Nothing happens when i tried to print from my computer the status is offline what is wrong
same thing, woring one minute, next minute, offline. cords plugged in , no reason i have found but it happens all of the time
9/12/2018 11:57:26 AM • HP DeskJet F380... • Answered on Sep 12, 2018
HP DeskJet F380 All-In-One Printer Logo
2,556 questions posted
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
lost installation cd need install
  • Office Equipment & Supplies
