Check out the HP website for support
HP Deskjet 1050 All in One Printer J410a Troubleshooting
SOURCE: Reset ink level for HP 460
try this, if you are in a windows environment, click your start button, select control panel, then double click printer, then right click the name or model of your printer, then select properties, then select maintenance, and then select ink settings. thats it
SOURCE: The printer doesn't reset after putting in new cartridges
did you take off that piece of plastic that coverred your new ink cartridge contact?
SOURCE: HP Deskjet F4180 colour lights flashing and printer offline
Hi I have exactly the same problem, and can't scan or make copies. I went to HP Online, and tried their advice, which didn't work. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00867129&lc=en&dlc=en&cc=us&product=3177566&rule=25623〈=enHP's solution made me realise it might be a scanner problem. I made a wild guess and kept the cover above the glass panel open. Turn off your printer, lift the cover up and turn on again. The lights should stop blinking and you should be able to scan/copy/print. I guess the cover prohibits the device to scan properly causing the blinking lights. Hope this helps!
SOURCE: New printer cartridge light still flashes printer
clean the contacts of cartridge carrier (the place you put cartridges in ) with a wet towel
