Posted on Jul 11, 2011
How to fix error code h4-00 on sharp ar-m201 copier
5 Related Answers
tehnik_bdg
Budi Raharjo
  • 91 Answers
  • Posted on Mar 04, 2009
SOURCE: Sharp AR-M207 Error Message
H4-00 means heat roller low temperature detection. It usuallly caused by 3 things :
1. The machine hang : You simply reset the error code by pressing : # * C * then input 14 then start.
2. If the error still displayed, open the side cover, feel the fusing unit ( don't touch, it is hot ), if the
fusing unit feels cold then the problem is the heater lamp ( inside the upper heater roller,
connected with anti heat cable and big connector ), you should replace it.
3. If the fusing unit feels warm or hot then the problem is the thermistor ( connected with small cable
and connector ), replace it.
san3409jl
  • 190 Answers
  • Posted on Jan 27, 2009
SOURCE: sharp AR-M201
Its normal as it does not affect your copy.Right
Anonymous
  • 2072 Answers
  • Posted on Jan 22, 2008
SOURCE: SHARP AR-M277
this should resolve it.
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly.
Anonymous
  • Posted on Oct 26, 2008
SOURCE: Error Call for Service H4-00
# - intrrup key - clear - interrup key 14 print
this all
check fuser lamp, thermost
just
Warrick Lee
  • 32 Answers
  • Posted on Mar 25, 2009
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
What does error f2- 02 mean
Toner sensor error. Replace the toner cartridge or toner chip. ok
3answers
Why ar m201 sharp copier shows error h2 00
it means that the thermistor in the fusing unit is open
which could indicate that it may have become faulty or is because of power fluctuations, a simple crop 14 reset should remove the error, but if it returns it should be looked at by a qualified sharp technichian
Ar m201 error h2 00
thermistor open , check thermistor , might have to replace
SHARP AR-M201 system error (E7-11)
E7-11 is a white level shading correction error. This code was intended to identify a dirty white level reference (located under the left edge of the copyboard glass).
This code has plagued certain individual Cougar machines. I have personally replaced CCD's, installed a foam damper to the top of the hard drive (to damp vibrations between the hard drive and the lens cover), and ICU boards, to no effect. Typically 3 to 7 times a day this code can pop up.
3helpful
System error (f2-04) for Sharp Copier, model AR-M201
It is copy lamp error.
1- check the copy lamp on with sim.
2- replace the power unit.
3- replace the inverter.
4- replace the mcu pwb.
3helpful
3answers
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
1helpful
2answers
Sharp AR-M201
no. i cant print. its showing red light and user guide attention
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
