ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
Anonymous Posted on May 07, 2008
Cannot install/uninstall Java
This is not about this product (this product relates to it) anyways, i wanted to play a java game. i went on it and it said that you do not have java installed. but i know i do! (yesterday i used it.) i went to download java. when i try to install it this pops up: "This software has alredy been installed on your computer. Would you like to reinstall it?" i click yes. then the windows installer loads a bit and again the same message pops up. i click yes again, and it loads a bit and then it dissapers. I go to add/remove programs. and there is java updates only. nothing else from java. i click remove, and this pops up "fatal error during installation" any help?
  • cja329 Apr 01, 2009
    I'm trying to install and reinstall java since I'm having problems with java... I get "Fatal Error on Installation". It will not uninstall. The Microsoft CleanUp Utility did not help. Any suggestions?
Anonymous
Level 1:
  • Contributor 30 Answers
  • Posted on Jul 23, 2008
Anonymous
Contributor
Level 1:
Answers
30
Questions
0
Helped
9608
Points
47
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
Top ArcMedia Computers & Internet Experts
Rob Hill
Rob Hill
Anonymous
Dax Estorioso
Dax Estorioso
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
