20 Most Recent ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Questions & Answers
4answers
Java is not working
Hello there :
first you are going to want to ensure that your your current version of java is installed correctly and is not corrupted and if it needs to be reinstalled
download the latest java version and reinstall this . www.java.com
this should be able to take care of the problem that you are having ok?
best regards michael
10/2/2018 9:06:28 PM • ArcMedia... • Answered on Oct 02, 2018
Annhen33 or email address annhen7@hotmail.com
Uninstall Java and reinstall with the newest version. In the future, do not update Java, just uninstall and install newest version.
8/29/2017 9:15:40 PM • ArcMedia... • Answered on Aug 29, 2017
2answers
Spell checker-project
You can look in an open source project like JOrtho at http://sourceforge.net/projects/jortho/ There you can also find the source code of the Java project.
3/19/2015 5:03:52 PM • ArcMedia... • Answered on Mar 19, 2015
Want miniproject using javascript & msaccess
HiI need the mini project in html & java script with back-endMs AccessKindly help me
11/9/2013 5:51:56 AM • ArcMedia... • Answered on Nov 09, 2013
Cant install java new version
it is java just right click on your task-bar near your clock and choose task manager look for jqs.exe right click it and choose end process.
11/9/2013 3:53:03 AM • ArcMedia... • Answered on Nov 09, 2013
0answers
0answers
Error message from IG when I try to launch advanced charts. I have one saying Java Virtual Machine Launcher, Error:Could not create the Java Virtual Machine, Error:A fatal exception occured, Program w
If you have backed up your system recently...just flash back to the last backup and undo the java update and re-install Java. Let us know how it goes.
4/13/2013 10:55:28 PM • ArcMedia... • Answered on Apr 13, 2013
0answers
Java
Be the first to answer 3/31/2013 2:39:45 PM • ArcMedia... • Posted on Mar 31, 2013Be the first to answer
Which version of java is installed on my computer ?
You can view the currently installed version of java by clicking on the link below:http://java.com/en/download/installed.jspOnce at the website, click Verify Java Version.
2/14/2013 2:40:40 AM • ArcMedia... • Answered on Feb 14, 2013
Java isn't running
check on the bottom of your browser for an exclaimation mark..double-click it and the location of the errors in your code will be mentioned in the resulting window. Fix it-& try again!
1/29/2013 6:42:37 AM • ArcMedia... • Answered on Jan 29, 2013
2answers
C++ programs
An array is a series of elements of the same type placed in contiguous memory locations that can be individually referenced by adding an index to a unique identifier
Initializing arrays. When declaring a regular array of local scope (within a function, for example), if we do not specify otherwise, its elements will not be initialized to any value by default, so their content will be undetermined until we store some value in them. The elements of global and static arrays, on the other hand, are automatically initialized with their default values, which for all fundamental types this means they are filled with zeros
include <iostream>
using namespace std;
int billy [] = {16, 2, 77, 40, 12071};
int n, result=0;
int main ()
for ( n=0 ; n<5 ; n++ )
result += billy[n];
cout << result;
return 0;
multidimensional array pseudo-multidimensional array #define WIDTH 5 #define HEIGHT 3 int jimmy [HEIGHT][WIDTH]; int n,m; int main () { for (n=0;n<HEIGHT;n++) for (m=0;m<WIDTH;m++) { jimmy[n][m]=(n+1)*(m+1); } return 0; } #define WIDTH 5 #define HEIGHT 3 int jimmy [HEIGHT * WIDTH]; int n,m; int main () { for (n=0;n<HEIGHT;n++) for (m=0;m<WIDTH;m++) { jimmy[n*WIDTH+m]=(n+1)*(m+1); } return 0; }
and now for trignometry
#include<iostream>
#include<cmath>
int main()
int factorial(int);
int n = 3, i = 1;
double x, x2, b, PI, r;
char choice;
//r = x * (PI / 180)
cout<<"Please enter an angle value => ";
cin>>x;
cout<<"Is the angle value in Degree or Radian?"<<endl;
cout<<"Type D if its in degree "<<endl;
cout<<"Type R if its in radian "<<endl;
cin>>choice;
if((choice = 'R')||(choice = 'r'))
do{
i++; n = 3; x2 = 0; b = x2;
if(i == 1)
x2 = x - (pow(x,n) /factorial(n));
n = n + 2;
else
x2 = (x2 + ((pow(x,n)) /(factorial(n))) - (pow(x,n+2)) / (factorial(n+2)));
n = n + 4;
}while(abs(b - x2) > 0.000001);
else
//convert it to r
r = x * PI /180;
//cout<<"error occured/n";
cout<<"sin(x) = "<<x2<<endl;
return 0;
1/26/2013 10:59:56 AM • ArcMedia... • Answered on Jan 26, 2013
Codes of BufferedReader and FileInputStream in one
class base{ int a,b; void display(int x,int y ){ a=x; b=y;} void dismax() { display(); if(a>b) System.out.println("first Value is greater"+a); else { } }} class dervd extends base{void dismin(){ display(); if(b>a) System.out.println("second value is greater"+b); else { }} public static void main(String args[])throws IOException { BufferedReader in= new BufferedReader (new InputStreamReader(System.in)); System.out.println(" Enter 1st value"); String s=in.readLine(); int m=Integer.parseInt(s); System.out.println(" Enter 2nd value"); String s1=in.readLine(); int n=Integer.parseInt(s1); base b1=new base();b1.display(m,n);b1.dismax();dervd d1=new dervd();d1.dismin();}}
10/31/2011 3:15:37 AM • ArcMedia... • Answered on Oct 31, 2011
2answers
I want mini project coding using java
Download free IT mini project for MSC & MCA student....... absolutely freeeeeeeeeee
watch & download ... enjoy.......
http://www.youtube.com/watch?v=cTWXDG6nK_8
thank u
7/1/2011 12:18:38 PM • ArcMedia... • Answered on Jul 01, 2011
Lorraineleach@yahoo.com fatal error msg
reset ip address turn computer turn your router off turn your cable box off wait 15 min. then turn every thing back on.
3/20/2011 1:37:52 PM • ArcMedia... • Answered on Mar 20, 2011
Need to download javscrip
go to java.com and that will do the trick
2/11/2011 2:42:50 PM • ArcMedia... • Answered on Feb 11, 2011
I want to uninstall java but fatal error comes
hi
you can turn your system back as it was
from windows files
get windows in previous date when java was not intalled
1/13/2011 12:29:50 PM • ArcMedia... • Answered on Jan 13, 2011
I have developed a website
Try reversing the load commands, so the other one is loaded first.
11/9/2010 6:10:22 PM • ArcMedia... • Answered on Nov 09, 2010
ArcMedia JavaScript Source Code 3000 Pro (gar448) for PC Logo
129 questions posted
Top ArcMedia Computers & Internet Experts
Rob Hill
Rob Hill
Anonymous
Dax Estorioso
Dax Estorioso
Are you an ArcMedia Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ArcMedia Computers & Internet
Most Popular Question
java not working
  • Computers & Internet
