Sharp AR-M160 Black and White Copier Logo
Posted on Jun 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How bring a sharp ar m160 printer drivers - Sharp AR-M160 Black and White Copier
Anonymous
Level 3:
  • Master 10,319 Answers
  • Posted on Jul 24, 2010
Anonymous
Master
Level 3:
Answers
10319
Questions
5
Helped
3134553
Points
30576
Http://www.driverwizard.org/wizard/w?ms.driversfor.wizard
3answers
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
1helpful
Sharp AR-M160 A3 Printing
You need to contact Sharp ! !
They are the ones who developed the new Windows 7 drivers and now they are defective! Call them back (Sharp), and tell them they need to give you a new driver that will fix the A3 issue of your printer.
27helpful
2answers
I need drivers of my sharp AR-M160 for windows 7 or windows vista,
Your printer doesn't support Windows 7.But it support Windows Vista.
Here is the driver download page from www.sharpusa.com
http://www.sharpusa.com/CustomerSupport/ProductDownload.aspx
Fill the form as below
Select a Product Category    :  MFPs & Printers
Enter Product Model             :  Models not listed
Enter Product Model             :  AR-M160
Select a Download Type        :  Driver
Driver Platform                      :  Microsoft
Operating System                 :  windows Vista
And click "search"
Your printer drivers will be listed below.Click on the driver name (Red colour text),your driver will be downloaded now.
Note : Drivers which are meant for Windows Vista usually Work with Windows 7 too.you can give it a try.
I WANT A PRINTER DRIVER FOR SHARP AR-M160
follow the link below:-
http://www.businessneedz.com/Sharp-AR-M160-AR-M205-Downloads.htm
plz rate the solution...
1helpful
2answers
Where to get driver for Sharp AR-M160 for Windows 7
http://www.bioticaindia.com/ar-m160.html
Here is a link to a driver you can try. It is very possible that there is not a driver available that is compatible.
Thank you,
lee
4helpful
2answers
Driver of the sharp printer AR 5316E for vista 64 bits
Currently Sharp does not have any specific drivers for this model that are compatible with vista. But if you go to www.sharpusa.com under customer support, product downloads. You might try using the AR-M160 drivers. They are practically the same machine. For the model choose model not listed and manually type in AR-M160.
10helpful
2answers
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
1helpful
Scanner problem
Here is a list of drivers.. Since I do NOT know your OS, this page has MANY OS options...
Good Luck
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
