Sony DSR-1500 Mini DV VCR Logo
Pasha Kolchin Posted on Mar 22, 2010
Error code 09-028
Sony dsr 1500p
error code 09-028
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Mar 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
6182
Points
17
Servo and tape path system error.
0 : Mode cannot be identified, or mode identification is
not necessary.
2 : Threading motor/FG/sensor
8 : Abnormal current detected.
If it’s not just a simple tape jam, then you have a problem with the loading mechanism. The best solution is to take the deck to a service center.
1helpful
Error codes c 31 70 of sony dsr 45ap
U can do one thing check the switch at the front of DSR is in remote or not. If it is not then.Then press the reset switch is just below the the LCD. or Press eject button with pressing power supply .
5helpful
3answers
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
2helpful
2answers
My cam is a sony dsr-390
Error code 91-258 is described as follows..
91- Microcomputer and its periphery device error
2- THREADING
5- S side reel FG
8- Detected abnormal current
Your camera got mechanical problem with Supply Reel and failed to load tape.
4helpful
2answers
91-215 error code
91-215 is "communication error between system control and keyboard." could be a loose cable, open fuse, capacitor problem, etc.
DSR 1500P problems loading tape
Are there any indications on the front panel at all? There should be an error code of some sort there. If not, I'll need to research this a bit. Please update this with any codes.
Thanks,
Dan
Sony DSR-1500P does not load tape
There should be smoe indication on the front of a problem. If not, then the load sequence is not completing and the unit should be sent in for service. These are pro decks that should only be serviced by trained personnel. There are a number of reasons why a taoe would not load. Without seeing the unit, it is extremely dificult to determine the cause. Are there any other details you can provide that might help me to determine possible causes? Can you observe the loading to see how far it gets?
Thanks,
Dan
I have a problem.error code 35-000,DSR 1500AP.what is this?
error 35-000 on a dsr-1500 is a cassette compartment position error. check to see if something is obstructing the movement of the cassette compartment.
12helpful
Sony DSR error code C31:30 & C31:23
Error codes definitions are bit technical and as follows...
C:31:30 error code shows problem of No FG signal when starting capstan motor.
C:31:23 error code shows problem of No S reel signal to system control.
Above info were taken from service manual and picture of service manual can be seen below...
Need further info, let me know.
Error code C:31:70
this is servo IC problem.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
