Computers & Internet Logo
Posted on Jan 03, 2010
Error11 - Intel Computers & Internet
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jan 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1677
Points
13
Check that this is not being caused by a virus affecting your machine with reimage's 5 min free scan test: http://bit.ly/4HWvKz
Reimage gave me a free repair key to test and I found it by far the most useful and insightful registry cleaner.
Lavadora aqualtis error11
F11: Pump Feedback Missing
Overhaul CN1
Overhaul CNF
Overhaul Pump Connector
Overhaul Pressure Switch Connector
Control Pump Windings
Replace Pump
Replace Card
Dado
1helpful
Inisperon 530s powers on and beeps
1 short DRAM refresh failure
2 short Parity circuit failure
3 short Base 64K RAM failure
4 short System timer failure
5 short Process failure
6 short Keyboard controller Gate A20 error
7 short Virtual mode exception error
8 short Display memory Read/Write test failure
9 short ROM BIOS checksum failure
10 short CMOS shutdown Read/Write error
11 short Cache Memory error
1 long, 3 short Conventional/Extended memory failure
1 long, 8 short Display/Retrace test failed
Advent Sienna 500 won`t switch on and keeps bleeping
First thing is to identify beep codes.
Beep Code Descriptions
I have problem vith my cd player in my car.It show me error11,my cd plauer is pioneer deh2600r.What shoud i do,help me.
If a car CD Player stops reading CD's, the LAST thing that will get dirt is the laser lens.
For cleaning the Optical Pick-up of the CDPLAYER You'll have to disassemble it completely and clean the internal mirrors.
If you don't know how to do this, or you don't have the tools, take it to a service center or you can run the risk of breaking the entire laser mechanism (it cost a lot of $$$ to replace, specially in a car CDplayer).
Cd player wont play
The error code is a mechanical error fault, possibly something in the mechanics that load the CD onto the spindle motor. The only sure way to know what the problem is, is to open the unit and let it load a disc and see what happens. The problem may also be due to a very dirty laser lens, with a dirty lens the laser won't be able to read the TOC (table of contents) and all the CD's will cycle through the changer and a error code will be set. Best of Luck.
Pioneer cdx P1280 error11
pnoman: Your code means an electrical/mechanical failure. Follow this: 1. If the cartridge is stucked try to force it out slowly with a fine screwdriver. 2. Once is out or if already out without forcing it, remove all remaining CD's. 3. Insert a laser lens CD cleaner. 4. Clean it at least 3 times. 5. The unit must be disconnected from the 12V signal to be reset it at least 5 minutes, then reconnect. 6. If problem re-appears repeat procedure once more. If problems still, your laser lens is damaged and need replacement. Probably from $40.00 to $55.00. SithPitt
Top Intel Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
