YouTube Videos Logo
Posted on Dec 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to turn on java script - YouTube Videos
Anonymous
Level 3:
Guru:
  • Master 1,738 Answers
  • Posted on Dec 07, 2009
Anonymous
Master
Level 3:
Guru:
Answers
1738
Questions
Helped
478067
Points
4963
You shouldn't have to turn on java, unless you have a firewall program on your computer. You can go through your help on your program and search on how to do it.
1 Related Answer
Anonymous
  • 507 Answers
  • Posted on Oct 20, 2008
SOURCE: java script
Thermador Hood VCH36+dimmable?
To turn on JavaScript within Internet Explorer 5.5 or higher:
* Open Internet Explorer
* Click on the "Tools" menu
* Under Tools, click on "Internet Options..."
* Within Internet Options, click on the "Advanced" tab
* Scroll down until you see the "Microsoft VM" heading
* Under Microsoft VM, "JIT compiler for virtual machine enabled" MUST BE CHECKED.
If it is not already selected, click on the box next to the JIT compiler option.
Click "OK" and then restart your computer before using Internet Explorer to come back to this Web site.
* NOTE: Some newer versions of Internet Explorer may not have "Microsoft VM" heading. If this is the case, then javascript may be enabled by default via another method. If you do not see the "Microsoft VM" heading and you are still having difficulty accessing other pages within this site, please call the Web Testing Helpline at (814) 865-8270 or email l-ftcap-tech@lists.psu.edu for further assistance.
Netscape Communicator 5.0 or higher:
* Open Netscape Communicator
* Click on the "Edit" menu
* Under Edit, click on "Preferences......"
* Within Preferences, click on the "Advanced" category on the left.
* When you click on Advanced, options will appear on the right.
"Enable Java" and "Enable JavaScript" (or "Enable native object scripting") MUST BOTH BE CHECKED.
* If they are not already selected, click on the boxes next to the "Enable Java" and "Enable JavaScript" options. Click "OK" and then restart your computer before using Netscape Communicator to come back to this Web site.
Mozilla Firefox 1.0.4 or higher:
* Open Mozilla Firefox
* Under Tools, Click "Options"
* Within Options, click the "Web Features" or "Content" tab
* Make sure "Enable Javascript" is checked
* If it is not already checked, put a check in the check box and click "OK." Then restart your computer before using Mozilla Firefox to come back to this Web site.
Java script
I got a zepad and when turning on has lines on it
1helpful
How do I go about downloading java script?
Java script is native to all browsers. You may have it disabled. You will have to go into your browsers settings and enable java script within your browser. If you have any plugins such as "No Script" then you will need to disable them or uninstall them for Java script to work properly again.
If you meant to ask how to download Java (it is different than java script) then you would visit http://www.java.com and download the software and install.
Seeing as you posted this as a Facebook problem I would be satisfied to say that your problem is java script is disabled in your browser settings.
2helpful
2answers
Unable to access jarfile c:\Program Files\Java\jre6\lib\librtexec.jar
sounds like this would be a java-script error. you can try re-install java-script http://www.java.com/en/download/ it might be a good idea before you re-install, to uninstall any instance of java from the control panel - add/remove programs, or programs and features section for vista/windows 7
How do i install java script being a guest
java script is not an installalbe item. java script is run inside the browser.
2helpful
2answers
I am yhabing a problem thaat i cannot open utube
download the lastest flash playe and latest java, instructions here to make sure everything is turned on
http://tinyurl.com/yd64pt2
Java script turned of
if you are using Windows xp
right click on internet explorer
take properties
under security tab click "custom level"
under scrippting you'll find javascript enable and disable option
after that click ok on all windows
restart your browser
If you are using anyother operating system please contact me.
Thanks,
HOpe that helps
Play Youtube
If you have no java runtime environment or have not been updated, you can update java and try this link.http://java.com/en/download/index.jsp. And I have flash player 8 which was downloaded together with the macromedia dreamweaver. You can search that in google and request for a dwonload.
Blessings.
2answers
How i install js script software
Java-script is a scripting language interpreted by you browser and is not installed on you PC like compiled software. Java, which is a programming language is installed by downloading JRE for www.sun.com.
If you browser is not running Java-script while viewing web-page, (eg: youtube) that is in you browser options, you probably need to enable JS in you settings. google "enable javascript YourBrowserGoesHere".
Heya I have problem for watching the vedios on youtube. I dont know how turn on the java ,and also have problem for installing the new version of adobe flash player.Dont know want to do. Can u help...
dear donya, Internet Explorer 7 To enable or disable Java:
  1. From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
  2. Click the Programs tab.
  3. Click Manage Add-ons.
  4. Highlight Java Plug-in.
  5. Under "Settings", click Disable.
  6. Click OK, and then OK again.
To enable or disable JavaScript:
  1. From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
    Click the Security tab.
  2. Click Custom Level... .
  3. Scroll to the "Scripting" section of the list. Click Disable or Enable.
  4. Close and restart your browser.
Internet Explorer 6 and earlier
  1. From the Tools menu, choose Internet Options... .
    in version 6, click Custom Level... .
    • Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
      JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
  2. Close and restart your browser.
download latest adobe flash player and install.
if u r using ie6, try to upgrade it ie7.
thanks,
When visiting a site such as Friends Reunited I cannot view the site as I keep getting a message up with a yellow exclamation mark in a triangle saying: Error in addLoadEvent:(object error). I have typed...
It appears to be a Java script error.
The chances are some pages your are visiting are using Java script to deliver multilayer messages or adverts.
If you didn't have Java script installed on your machine you would get an error along the lines of "page was unable to load" so I am guessing your Java script needs updating.
Go to this site: http://www.java.com/en/ you can either download Java or have the site check your computer to see if it has the latest copy(easiest method).
Top YouTube Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
ADMIN Andrew
ADMIN Andrew
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
