Pool & Spa Logo
r
rich anderson Posted on Jun 21, 2019
What error code E01 indicate on a Pentair Mastertemp400 pool heater?
If cycling check ignitor see if glowing if ok check gas
rogerpaul3
Level 1:
Habit-Forming:
New Friend:
  • Contributor 64 Answers
  • Posted on Jul 06, 2019
rogerpaul3
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
64
Questions
0
Helped
72153
Points
80
Eo1 error code indicates temp sensor failure. Replace temp sensor. If problem persists then replace control board.
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Dec 21, 2008
SOURCE: i have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Anonymous
  • Posted on Jan 02, 2009
SOURCE: Sta-Rite SR400 heater displays error E01 and doesn't fire.
Resolved - the thermister was bad.
Anonymous
  • 61 Answers
  • Posted on Apr 04, 2009
SOURCE: Pool heater will not heat
Im no pro, but I know there is an air sensor behind the main board. If the fan is running you probably have a problem with that sensor. If your lucky the air hose could have just popped off.
Anonymous
  • 990 Answers
  • Posted on Jan 26, 2010
SOURCE: E04 comes on after fan purge cycle-Pentair minimax nt pool heater
This is a fan falure code. It can mean the fan has problems (not likley if the fan goes and isn't labored) You have a sensor in your exaust (probally not this if you don't get a good start) The culperet is probally in the negetive pressure sensor. This is a 2-3 inch disc with wires going to the controls and a rubber tube going to the fan. Pull the tube from the fan and make sure the fan fitting is clear (poke with a tooth pic) Be sure their are no kinks in the hose. If the heater is 4 years old the diaprahm could be bad in the pressure sensor. Check the other things first but this is probally your problem. Good luck, hope this helped.
Anonymous
  • 760 Answers
  • Posted on Jul 05, 2010
SOURCE: CE error code on hayward pool heater
CE= Communication Error between Control Module
and Display Interface Assembly
1. Disconnect and then reconnect power to heater.
2. Check for faulty wiring or connection.
Inspect Display Interface Wiring. Ensure Display Interface Plug is securely attached to Control Module. .
3. Control Module and/or Display Interface Assembly
are defective.Replace Control Module and/or Display Interface Assembly.
Here is a linkt oH aywardmanuals:
http://www.haywardnet.com/inground/products/manuals.cfm
Top Pentair Pool & Spa Experts
john h
vince
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
