20 Most Recent Bose 901 VI Main / Stereo Speaker Questions & Answers
2answers
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
2/6/2023 10:39:49 PM • Bose 901 VI Main... • Answered on Feb 06, 2023
3answers
Connecting Bose 901 series iv to Harman Kardon AVR 254
Most HK av receivers have pre amp out,power amp in with metal jumpers connecting them for the main or front channels. that would be the best place to hook up the EQ on a AV receiver. If your receiver doesn't have pre out, power in jacks , you can use tape monitor .record out playback in. The tape monitor option is best for stereo use , as the active EQ will charge all speakers in tape mode, possibly damaging other speakers.I run my 901 s with a seperate pre-amp,power-amp hooked up to my Denon AV receiver that way i can run in surround w/standard speakers
6/28/2022 12:25:00 PM • Bose 901 VI Main... • Answered on Jun 28, 2022
2answers
Bose 901EQ connect to mixer and amp
Option 1: Adding a Separate Power Amplifier - Best Option https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr This option requires that you add a separate power amplifier. 1) Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right 2) Connect your 901 speaker to the power amplifier outputs 3) The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes. adding a separate power ampifier-bsgkn5rmzo15xr1s5rsozxgo-d-0_7.jpg
6/26/2022 3:01:44 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
Adding Subs to a Bose 901 system
You would need to use a modern equalizer like the EQ901 PS which has a built in crossover and four outputs. This would be connected in the pre-out / main-in loop of your Marantz 2285B. minidsp eq901ps-ii-bsgkn5rmzo15xr1s5rsozxgo-d-1.jpg
6/26/2022 2:47:53 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
Bose 901 v1 adding a amplifier
Option 1: Adding a Separate Power Amplifier - Best Option https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr This option requires that you add a separate power amplifier. 1) Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right 2) Connect your 901 speaker to the power amplifier outputs 3) The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes. adding a separate power ampifier-bsgkn5rmzo15xr1s5rsozxgo-d-0_6.jpg
6/26/2022 2:38:41 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
5answers
Bose 901 speakers the wiring inside
- Bose 901 Series I and II speakers have 8 Ohm impedance each.
- A row of 3 speakers in series gives you 24 Ohm.
- 3 parallel rows gives you finally 8 Ohm.
Front with 8 speakers (view from the rear):
(1) (3) (5) (7)
(2) (4) (6) (8)
Rear speaker is number (9)
Row 1: -(1)+ -(3)+ -(7)+
Row 2: -(5)+ -(9)+ -(2)+
Row 3: -(8)+ -(6)+ -(4)+
6/26/2022 2:35:03 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
My problem is conect bose 901v to reciver yahama
Here are three options to connect your EQ901B or a BOSE 901® Equalizer to a typical Audio Video Receiver (AVR). See: https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr Option 1: Adding a Separate Power Amplifier - Best Option This option requires that you add a separate power amplifier. 1) Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right 2) Connect your 901 speaker to the power amplifier outputs 3) The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes. Option 2: Setting up Your EQ901 B Using Zone 2 Loop 1) Connect Zone 2 pre-out to the EQ901 input 2) Connect the EQ901 output to any unused analog input 3) Select the Zone 2 source as any input (i.e. CD player) 4) Select the Zone 1 source to the input selected in step 2 The equalized signal will now play through the front speaker outputs in Stereo Mode Zone 1. Option 3: Setting up the EQ901 B Using Only a Single Source 1) Use this option if you have only one source. This example uses a CD player 2) Connect the EQ901 B in between the CD player and any AVR input 3) This may require the 2V input mode on the EQ901B The equalized signal will play only the single source (i.e. CD) when the input referenced in line 2 is chosen adding a separate power ampifier-bsgkn5rmzo15xr1s5rsozxgo-d-0_5.jpg
6/26/2022 2:30:01 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
Onkyo tx sr705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
6/26/2022 2:14:37 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
Can I hookup a Bose 901 EQ to my receiver and amp?
Your instincts are correct. In fact, the only way the 901's can live in an A/V system is with dedicated amplification.
Put that old amp back to work.
This is exactly how mine are connected.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ's Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
6/26/2022 2:00:36 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
2answers
How to connect my bose 901 to rx-v2200
You can do this however you will need a separate power amplifier. See notes here: https://deercreekaudio.com/blogs-%26-updates/f/connecting-your-eq901-to-an-audio-video-receiver-avr
  1. Connect the pre-out main left and right to the EQ901 inputs 1 and 2, and the EQ901 outputs 1 and 2 to the power amplifier inputs left and right
  2. Connect your 901 speaker to the power amplifier outputs
The equalized signal will now play through the front left and right speaker outputs in the stereo and home theater modes. adding a separate power ampifier-bsgkn5rmzo15xr1s5rsozxgo-d-0.jpg
6/26/2022 1:16:41 PM • Bose 901 VI Main... • Answered on Jun 26, 2022
How can i hook up my 30gb Ipod to my Bose 901
There has to be some amplification in here somewhere. Any single amplifier will not work correctly with the Active EQ for 901's applied to non-901 speakers.
Any MP3-player device with at least a headphone output can feed any standard audio device that has a Line Level input (other than "PHONO") once the output is adapted to fit the input.
9/3/2020 1:32:14 AM • Bose 901 VI Main... • Answered on Sep 03, 2020
Connect pioneer vsx-9700s receiver to tech.equalizer??
If there is no rca connection on the back labeled something like "external processor" then it could probably go through a tape loop. At least that's the way it used to be done last millenia. ;)
11/8/2016 10:16:36 PM • Bose 901 VI Main... • Answered on Nov 08, 2016
3answers
Will Bose 901 active equialiser connect to SONY AV1100 Receiver
http://www.bose.com/pdf/customer_service/owners/og_901.pdf
9/3/2015 2:42:52 PM • Bose 901 VI Main... • Answered on Sep 03, 2015
3answers
Best amps for bose 901
You need an amplifier with at least 200 wpc to get the most out of your BOSE. Look into getting a NAD, ADCOM or CARVER amplifier. I prefer CARVER myself. I am running a CARVER M-500T(251 wpc) on my 901's and they sound incredible.
9/3/2015 2:36:05 PM • Bose 901 VI Main... • Answered on Sep 03, 2015
What kind of amplifier and
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
8/2/2015 2:01:10 PM • Bose 901 VI Main... • Answered on Aug 02, 2015
What is a good placement for the 901 series VI speakers? I've heard the backwall is half the distance to the sidewall
Depends on the shape and contents of the room. Look up "best acoustic placement of speakers" in your web browser. Good Luck!
12/10/2014 8:30:38 PM • Bose 901 VI Main... • Answered on Dec 10, 2014
What would be the correct placement of the Bose 901 series VI?
This fully depends on the room. If it is a simple square room, set the front speakers left and right about 2 meters from your TV, try to do the same at the back. Point them slightly into your direction and try if this sounds good for you. If not you could try to turn them.
11/12/2014 10:45:01 AM • Bose 901 VI Main... • Answered on Nov 12, 2014
Bose 901 VI Main / Stereo Speaker Logo
270 questions posted
Top Bose Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Bose Audio Players & Recorders
Most Popular Question
bose 901 speakers wiring inside
  • Audio Players & Recorders
