20 Most Recent Yamaha RX-V995 Receiver Questions & Answers
Yamaha RX-V995: Remove On Screen Text
Here is a dumb try :). Connect your video source directly to the TV/projector, bypassing the receiver from inserting any messages.
If you are probably going to HD sometime, you would need to do that eventually as 995 doesn't have HDMI/Digital Video switching.
11/25/2022 12:20:20 AM • Yamaha RX-V995... • Answered on Nov 25, 2022
3answers
RX-V995 Won't Start - Found Possible Fix But Need Parts
HI,
Start by checking the fuse, take the cover off the reciever and look for a small glass fuse attached to the board. If it's blown replace it.
7/19/2019 5:31:54 AM • Yamaha RX-V995... • Answered on Jul 19, 2019
0answers
Hi i have a yamaha rx-v995 reciver and just
1) Check to see if the screen says "EXT DECODER". If it does, press the EXT DECODER button again and this should fix the problem
2) Press input mode button until the display reads auto or digital. It may be set to analog.
12/9/2016 1:59:46 AM • Yamaha RX-V995... • Answered on Dec 09, 2016
2answers
When I try to turn up/down the volume from the remote the knob on the reciever does not move. I can hear the motor trying to compute the command of the volume. All other functions work on the receiver
Remove the volume knob by pulling it straight out off of it's shaft. Use a dry cloth to clean off any visible crud and dust. Spray silicone lightly; the shaft and the shaft washer. Replace knob by aligning it by it's shape and work the silicone into the volume mechanism by twisting the knob a few time. Now try it with the remote.
9/20/2016 10:48:31 AM • Yamaha RX-V995... • Answered on Sep 20, 2016
0answers
Is it a good idea to upgrade capacitors in power supply,nd othe routput areas
You can replace with elna rubycon FRAKO or F&T caps a good size , but aware that you will have the capacity exactly the same and the voltage a 10 volt higher because of new capacitors of the same value can have a smaller size with the same voltage and capacity and the little size format can be giving a not nice sound but also all replacement capacitors in the beginning have a 2 days neccesary Black-gate or some ELNA caps much longer before it will sounds good , if you have had leaking caps like the brand of ITT if used especially the big blue ones, or nichicons clean the print outdoors with a nose pliers use on a canister gaslighter gas and spray on the free positions on the print where the leaking capacitors where placed and also to clean the whole print . it removes conductive materials and also if you have ones in your life have wallpapered indoors and have prepared wallpaper paste and this amp was in the same room you have luck by this tip because methyl cellulose can be highly conductive eventually creep and especially static seen very high electric malfunctions if you get your fingers on places without cleaning also after years !!! , and now you have your amplifier open and wish to customize it its your chance to prevent hidden faults, especially if you want to brush up on vintage equipment with analogue techniques. Yamaha vintage capacitors if you have a capacitance meter you will see if you have a capacitor that looks good in most times if you measure it you have sometimes a remarkable value because the capacitors have a strange tolerance that will not deformed down but to high 100 mf can be have an capacitance of 230 mf too great tolerance that is not a problem if all the capacitors are not replaced , but if you have checked this you will know you must replace ALL the capacitors at the same time (not the very little ones ) but measure is important or there are components that will be burning out , strange and remarkable but it could happens. good luck .
1/3/2016 7:01:17 PM • Yamaha RX-V995... • Answered on Jan 03, 2016
How do i connect an equalizer to a Yamaha rx-v995 reciever?
Connect the EQ to the Tape IN and OUT jacks and switch the Rec OUT/Zone 2 to Tape/MD. That is my best guess without having the owners manual....
1/9/2015 7:40:50 PM • Yamaha RX-V995... • Answered on Jan 09, 2015
Yamaha RX-V995 no power no audio [dead]
sounds like a short in the cpu of the unit
7/31/2014 6:11:33 PM • Yamaha RX-V995... • Answered on Jul 31, 2014
How do i connect an equalizer to aYamaha rx-v995 reciever?
How to Hook up an Equalizer The above link describes how to hook up the equilizer to the receiver.
5/24/2014 2:23:19 AM • Yamaha RX-V995... • Answered on May 24, 2014
How do you connect a Nakamichi surround sound system to my Phillips tv model 42PF7220A/37
I'm confused. The message header shows a problem with a Yamaha RX-V995 receiver. As for connecting a Nakamichi (or any surround system) to a TV - the only connection would be the Monitor output (video connection) to an appropriate video input of your TV. If it is a Nakamichi, it is a little older and probly predates the invention of HDMI cables. My guess is you will either use the S video output or Composite video output to the TV's input with similar connections. This allows you to route whatever video sources you have connected to the Nakamichi to the TV.
5/11/2014 2:29:58 AM • Yamaha RX-V995... • Answered on May 11, 2014
Yamaha RX-V995 Receiver Logo
74 questions posted
Top Yamaha Audio Players & Recorders Experts
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Yamaha Audio Players & Recorders
Most Popular Question
connect nakamichi surround sound system
  • Audio Players & Recorders
