Hi please help me ! I need unlock code for
Nokia C7 - 00
Country: Canada
IMEI: 356252048301979
Provider: WIND
Thanks you
To unlock you Nokia E-63-1 (if forgot or lost lock code) you can unlock it using a master code.
To get the master code i need the IMEI code of your mobile phone.
- With the help of this IMEI code we can get the master code of your mobile and unlock the mobile and reset it with a new password.
- The IMEI number can usually be found on the sticker underneath the battery or by typing *#06# into the phone keypad.
Hope this helps.
Please rate if this solution helped you, thanks!
Hi, it is a C7 not a E63 the IMEI no is 355379043146124
Hi Paul,
Here is the master code for your Nokia C7;
IMEI = 355379043146124
Master Code = 5641332107
Good luck,
Please don't to leave a comment and rate me up, thanks!
Hello Robertaji,
I have also Nokia C7 locked to T mobile UK, IMEI code is 3537 5504 4049 155
Sorry for the delay Apu, the same master code would have worked for youy c7 too, still
the master code for your C7 mobile is 4246536762
Hope this helps please leave a comment, thanks.
I can not activate with these two codes, can you help me further little bit? I am using this format #pw+mastercode+1# and it says not allowed on both codes, i tryed different numbers at the end 1,2,3,4 and etc but it says same.
Ok, in that case please send me the Country, network your are using, IMEI and Model (ok, C7).
Try these codes;
CODES:
#pw+721627027126224+1#
#pw+515655211536057+2#
#pw+330263633062565+3#
#pw+354533356455236+4#
#pw+776447376604340+5#
#pw+722037323250131+6#
#pw+120121323061726+7#
How to use:
- Remove SIM card and turn phone on. Enter code in to main screen.
- To get the p push your * key 3 times, the w is the * pushed 4 times.
- Dont forget to remove SIM card, when entering codes! After entering unlock code phone will display: SIM restriction off
- when lock has been successfully removed; Code error - when entered unlock code is wrong; Cant undo restriction
- when you have tried to enter wrong codes too many times. -
- You have only 5 tries to enter proper unlock codes! After that your phone can be unlocked only via cable, unlock codes wont work anymore!
it doesnt work, probably i entered wrong code too much time. how can i unlock it with cable? can i do it at home?
For that you have to take your mobile to the nokia service centre
hello .. I have a problem with my nokia c7 has the orange card, and I want to put a 'else! No I can unlock it! imei: 356552043187332
hello .. I have a problem with my nokia c7 has the orange card, and I want to put a 'else! No I can unlock it! imei: 356552043187332!!! help me!!
hello .. I have a problem with my nokia c7 has the orange card, and I want to put a 'else! No I can unlock it! imei: 356552043187332!! help me!!
Hi
Ulock code for your c7 nokia #pw+9539169703 +1#
How to use:
- After entering unlock code phone will display: SIM restriction off - when lock has been successfully removed; Code error - when entered unlock code is wrong; Cant undo restriction - when you have tried to enter wrong codes too many times.
-After that your phone can be unlocked only via cable, unlock codes wont work anymore!
I'm sorry, but the code is complete? nothing is missing? you entered does not give me anything
the cell tells me: Operation not permitted
In that case your phone can be unlocked only via cable, unlock codes wont work anymore! please contact the customer service. Good luck!
hi got a c7 need unlock code and IMEI is 356978040768811
it would be better if you guys send me your country and network provider too to get the best result. Any way the master code for your nokia 7 is 0442253042.
please rate , thanks!
Hello Robertaji, I have also Nokia C7 and I need the master code, as I lost the security code!
IMEI code is 353755048841854
Thank you in advance for your help!
Master Code 2036601671
Hi Robertaji! Thank you for your quick reply!
Unfortunately the code you sent me, didn't work! :-(
Maybe I did something wrong? Not sure!
Is there any other solution to reset or to change the the security code? If yes... how?
Thank you in advance!
Any solution please...???!! :-(
Thank you!!!!
send me the details like your country and network provider etc, I will try.
Hello Robert Aji... thanks for your reply!
Nokia C7 - 00 Charcoal black
Country: Greece
IMEI: 353755048841854
Provider: WIND
My phone is lot locked, as I bought it from a shop in the internet,
and its a Switzerland edition... so the Country of origin is Switzerland.
Thankk you in advance!
Sorry, Our data base does not have the master code for Nokia C7 in Greece networked with WIND.
For good place to get the unlock code for Nokia model, visit this site Wickedunlock.com, it provides step by step instructions and easy ways to unlock the phone lock network ..... while for the unlock code you have to give some information about the mobile site that is your IMEI number, network and country lock, then in a short period you can get the code ...
Hey I Have Nokia C7-00 from Mtel (Vodafone) Bulgaria IMEI is : 355960045436975 Please help me.
Hello! my nokia c7-00 is locked in wind canada. imei: 356252041552644 can someone plz send me a unlock code for network restirction? thnx!!!!! in this email plz ---> admin@postaime.com
Code restore
NOKIA C7 VODAPONE UNLOK COD IMEI 353755047618592 PLZ HALP
Nokia C7-00 Frosty metalCountry: UKIMEI: 355379043176618Provider: 3
I havr aphone Nokia C7 locked in Vodafone Australia .How can i unlock ? Thanks, F Morgan
hey I Have Nokia C7-00 from Mtel (Vodafone) Bulgaria IMEI is : 355960045436975 Please help me.
