You may have scripting disabled in your Internet Explorer. To enable scripting:
Click "Tools" Click "Internet Options." Click "Security" tab. Click "Custom Level" button. Scroll down to "Script ActiveX.controls marked safe for scripting"- enable Scroll down to "Scripting - Active scripting" - enable Scroll down to "Scripting of Java applets" - enable Click OK Click OK Restart IE
Still not working ? Update software
use the links on this page to help update software.
After updating check you do not have old versions of Flashplayer, Shockwaveplayer and Java running alongside the latest - this can cause conflicts Start / control panel / programs delete any old versions
1. Select Tools from the top menu 2. Choose Internet Options 3. Click on the Security tab. 4. Click on Custom Level. 5. Scroll down until you see section labeled Scripting. 6. Under Active Scripting, select Enable. 7. Click OK to save changes. 8. Close and restart Internet Explorer.
Internet explorer 7:
1. Open your browser. 2. Click on Tools button (it is located in the upper right part of the screen) 3. Select Internet Options. 4. Click on Security tab. 5. Click on Custom Level. 6. Scroll down until you see section labeled Active Scripting. 7. Select Enable and click OK. 8. Click OK to save changes. 9. Confirm Yes and click OK. 10.Close and restart the browser.
Enable the Sun JRE though your Web browser:
1. Click "Tools" --> "Internet Options" 2. Select the Advanced Tab, and scroll down to "Java (Sun)" 3. Check the box next to the Java version 4. Next, select the Security Tab, and select the "Custom Level" button 5. Scroll down to "Scripting of Java applets" 6. Make sure the "Enable" radio button is checked. 7. Click OK to save your preference.
Click "Tools" in the menu bar, and then select "Internet Options".
Click the "Security" tab. For the Internet zone, be sure that the
Security level is set to "Medium" or below. (If you have chosen to
customize your security settings for the Internet zone, be sure that
under the Java heading, "Java permissions" is not set to "Disable
Java." You will want to select one of the three safety levels instead.
Also be sure that under the Scripting heading, "Scripting of Java
Applets" is set to "Enable" or "Prompt.")
Next, click the "Advanced" tab.
Scroll down until you see the sub heading "Java"
Check the boxes next to "Java JRE"
Firefox 3.5 for Windows
Click "Tools" in the menu bar, and then select "Options".
Click on "Content".
Put checks in the boxes next to "Enable Java" and "Enable Javascript".
dear donya,
Internet Explorer 7
To enable or disable Java:
From the Tools menu, or the Tools drop-down in the upper right, select Internet Options... .
Click the Programs tab.
Click Manage Add-ons.
Highlight Java Plug-in.
Under "Settings", click Disable.
Click OK, and then OK again.
To enable or disable JavaScript:
From the Tools menu, or the Tools drop-down in the upper right, choose Internet Options... .
Click the Security tab.
Click Custom Level... .
Scroll to the "Scripting" section of the list. Click Disable or Enable.
Close and restart your browser.
Internet Explorer 6 and earlier
From the Tools menu, choose Internet Options... .
in version 6, click Custom Level... .
Java: Scroll to the "Java" section. (In version 6, you will find this section under "Java VM", under "Java permissions".) To disable Java, click Disable Java. To re-enable Java, click a different setting, such as High Safety or Medium Safety.
JavaScript: Scroll to the "Active scripting" section of the list. (In version 6, this is under "Scripting".) Click Disable or Enable.
download latest adobe flash player and install.
if u r using ie6, try to upgrade it ie7.
thanks,
