Computers & Internet Logo
Posted on Feb 28, 2017
Hello, I have a problem with the SIP registration on the ATA MP-202 B 2FXS For example, after uploading my configuration file, the line of my ATA will have the status "Not registred" on "Sip registration". I must press OK on "Signaling protocol" tab on "VoIP" field to register my line. I wish it would be done by itself. How I can set up this? For your information I'm editing directly the main conf file. Well it's a point but I have another problem : In my conf file i chosed to unencrypt the password. So i use this command : (auth_password(toto)) (i cant set the true characters in this log) on "line parameters" on "VoIP" field. I found this command in the tutorial for the last software version (the one i'm using) but it doesn't work, my CA doesn't recognize this password I checked the conf on MP202B interface and it shows me this : (auth_password(toto)) So I supose it understood that the password isn't encrypt but it not doing the hash by next. Just to clarify, the problem doesn't come from my CA because with the crypted password it works. But I'm doing an Excel in which the customer can type the password he wants and that transcribe it in the line (auth_password("the_password_typed")) i cant set the true characters in this log) Even i have no way to crypt the password typed, can you tell me why the syntax {"password"} doesn't work for un-encrypt it ? I would be very grateful if someone could help me. Sincerely. Jesson FRANCOIS
5 Related Answers
El Geek
Carlos Soto
  • 149 Answers
  • Posted on Jun 13, 2009
SOURCE: Network connection problem - need
Run the winsock fix. If you don't have it, try: http://winsockfix.en.softonic.com/download#pathbar This is a direct link so it may not start automatically, but just click on the "click here" button. Good luck.
Anonymous
  • 11 Answers
  • Posted on Sep 14, 2009
SOURCE: my voip settings for TPG internet are not working.
http://www.allnet-italia.it/img/speciali/pdf/777702433.pdf
Anonymous
  • Posted on Mar 03, 2010
SOURCE: Configure Nokia N95 to work with SIP with my MWEB account
code for IMEI 359757002671065
Michael Vincent Cruz
  • 868 Answers
  • Posted on May 16, 2011
SOURCE: Please help me configure this
Hi findpjemerso,
I see you dilema here, have you tried resetting the router first before reconfiguring the Router?.
mvincentc
Jeff Parker
  • 99 Answers
  • Posted on Feb 18, 2012
SOURCE: breaking password on cisco 857w
When the router first starts booting you need keep hitting the break sequence which should be crtl+F6 and that should bring you to ROMMON mode. you should get a prompt rommon 1>, that means you did it right. Now you need to change the configuration registers to 0x2142 by typing "confreg 0x2142". then type reset to restart the router. It should now ignore the saved config. hit crtl+c to cancel the initial setup, type "enable" to get to the enable prompt. Next type "copy startup-config running-config" to copy the startup configuration to the running configuration. Next type "configure terminal" to enter global configuration mode. Now you can type "enable secret <password>" to change the password to what you want. Last you need to change the config registers back to 0x2102 by entering the command config-register 0x2102.
Top AudioCodes Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an AudioCodes Computer and Internet Expert? Answer questions, earn points and help others
