How to program a digi-key remote control :
- on the wall console press the light toggle button to switch the light off.
- press and hold the light toggle button, the light will come on and after 5 seconds go off.
- release the button and the light will go on again.
- within 30 seconds press the required key on the digi-e key transmitter (your remote control). The light on the digidoor ac/dc will go off.
- to confirm press again the same button the transmitter (remote), the light on the digidoor ac/dc will flash foor times. Done
Any idea if you don't have the wall console?
Without the wall console, instead of pressing the light, bridge the 'light bulb' and 'neg' terminals on the motor.
The above I got right with the 1st remote, but how do you program the 2nd remote on the same program frequency/setting?
Each time I follow the same process for the second remote it throws out the programming frequency/setting of the 1st remote.
Your receiver is full. Each time you try and add another remote it will overwrite the last memory location. You will need to erase the receiver (press and hold light button for 30s) then reprogram all remaining remotes.
I am experiencing a problem in programming my digi@key remote with four buttons. It has a code button, set button, up button and down button. The light button I don't know. The light does not shine and not matter where I press. This motor has keys on board.How do I programme this on.
Hi, I have a question. Recently moved into a new house with a Digidoor II garage motor and wall console. The original setup used a Centurion Nova remote on the gate and garage (4 button remote). I followed the setup using the wall console for a new Centurion Nova remote i bought as a spare to which it acknowledged the setup however when i attempted to use it it did not open the garage door yet the older remote i received with the house still does? What am i missing?
Sorted!
I am trying to program a new digi keyy remote but now the existing remote wont open the door either
