Televison & Video Logo
Posted on Apr 13, 2011
HI, I NEED A CODE FOR MY REMOTEC UNIVERSAL REMOTE,INSIDE THE BATTERY COMPARTMENT IS SAYS WR09016
5 Related Answers
A
Anonymous
  • Posted on Jan 30, 2008
SOURCE: remote code list numbers
Sorry for that,
As i was to say the tv is a brand name DEC, which are made up of either toshiba sanyo or phillips parts,
The remote is a Brand nake Remotec, the only model nuber i assume is in the battery housing which are these
R30520 and a seperate number 711002020 00,
Hope this helps
Cheers waitng for your help
A
Anonymous
  • Posted on May 06, 2008
SOURCE: Remotec Remote - lost instructions and need to reprogram
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly alternate between pressing
POWER and TV. Stop when the TV turns off (after pressing POWER).
If the device does not have a Power key, you can substitute another
function, such as digits 0~ 9 , CH▲, or PLAY).
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and release SET.The LED will blink twice.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Anonymous
  • Posted on Feb 27, 2009
SOURCE: Zenith universal remote control
I have this same remote with the same markings in the battery compartment. This remte is the same as Phillips/Magnavox model PM725. You can download the PM725 manual here: http://www.remotecentral.com/index.html
Anonymous
  • 152 Answers
  • Posted on Apr 15, 2009
SOURCE: device code for universal remotec remote
I need the model number of the remote to help you.
Thanks,
Jim
Anonymous
  • 6 Answers
  • Posted on Apr 22, 2009
SOURCE: trying to get remotec universal remote to code up with teac tv
teac codes try 2551 2771 2791 or 0001
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
