Hello 1. Manually turn on the TV. 2. Locate the enclosed TV Code List. Find your brand of TV. Note: If your brand is not listed, use one of the Code Search methods to program this remote control. (See section on Code Search.) 3. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key. 4. Press and release the TV key. The indicator light blinks and then remains lit. 5. Use the number keys to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off. Note: If you enter an invalid code, the LED flashes rapidly for two seconds. Start over at step 3. 6. Aim the remote at your TV and press the ON•OFF key. If your TV turns off, you have found the correct code. 7. Enter the code in the box provided on this page for future reference. 8. If your TV doesn't turn off, repeat steps 3-6 above, entering the next code for Manual Code Search 1. Manually turn on the component you want the remote to operate. 2. Press and hold the CODE SEARCH key until the indicator light illuminates. Then release the CODE SEARCH key. 3. Press and release the component key that corresponds to the component you want the remote to operate (TV, VCR, DVD, DBS•SAT, CABLE, AUDIO). The indicator light blinks once and then remains lit. 4. Aim the remote at the component. Press the ON•OFF key continuously until the component turns off. Important: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times. 5. When the component turns off, press the ENTER key to store the code. 6. Use the Code Retrieval section on the next page to identify the code for your component for future reference. OK
According ro RCA Codes for sanyo are detailed as
Code 004 for sanyo tv
Code 048 for Sanyo TV
Code 049 for Sanyo TV
Code 073 for Sanyo TV
Code 080 for Sanyo TV
Code 107 for Sanyo TV
Code 162 for Sanyo TV
Code 169 for Sanyo TV
Code 180 for Sanyo TV
Code 196 for Sanyo TV
Just check with these codes according to the proceedings.
your brand.
SOURCE: sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
