Televison & Video Logo
Posted on Oct 03, 2017
I need a code for a Samsung HT-AS720S Digital Surround AV Receiver, I have tried the codes provided and just about every Samsung code I can find. The searching for codes doesn't work, checking the codes comes up with 1500 which is one of the codes listed but does not work.Other components I have programed in work fine just can't get the receiver to work.
5 Related Answers
Anonymous
  • 363 Answers
  • Posted on Sep 26, 2007
SOURCE: Brand Code
Which Universal Remote Control do you have?
ANTHONYPAULB
ANTHONYPAULB
  • 17 Answers
  • Posted on Nov 30, 2007
SOURCE: Samsung program codes for ht-q100 Remote
You can try any of these 006, 011, 014, 015, 019, 027, 036, 037, 077
Hope this helps..
A
Anonymous
  • Posted on Sep 30, 2008
SOURCE: Innovage Jumbo Remote Control codes for Viewsat Satellite Receiver
buy a harmony 550 remote
Anonymous
  • 2071 Answers
  • Posted on Jan 28, 2009
SOURCE: need remote code for programming a bell expressvu receiver
Here for the Jensen remote just click below;
Here is link to the manual:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Here is some helpful information I found:
Without the code on JER-323:
1.Manually turn on the component you want the remote to control.
2. Press the device button, example:( TV) and the (power button) for 3 seconds until the (on/off button stays lit).
3. Once the (on/off) button is lit, press the (on/off) button until the unit (the TV or unit you are trying to control.) turns off.
4. When the code is located, press the (stop) button at the bottom to save the code.
Here are some codes I found for the Jensen 323:
GE VCR: 2000, 2013, 2021, 2022, 2053, 2087, 2089, 2091, 2115, 2120
Motorola Cable Box: 5000, 5003, 5046, 5047, 5052
Mitsubishi TV 0093, 0150, 0178, 0019
JVC VCR 0067, 0041, 0008
JVC DVD 0558, 0623
Hope it may help you;
Regards,
VOTIT
veganjo
  • Posted on Feb 18, 2009
SOURCE: the sharper image jumbo touch
The instructions that came with my remote were COMPLETELY incorrect. I made note in pen in my jumbo remote manual. After hours of searching the web and piecing together various blogs, I wrote these easy-to-use instructions:
  1. Place the jumbo remote and your old remote on a flat surface, head to head, with a 1" to 2" space in between (the remotes should be aiming at eachother).
  2. Press and HOLD the device button on the jumbo remote (eg. TV) until the jumbo remote's small indicator light turns solid red.
  3. Press the LEARN button once on the jumbo remote. The light will blink rapidly.
  4. On the jumbo remote, press the button that you want to perform the learned action (eg. If you want the jumbo remote to turn your TV on and off, press the POWER button on the jumbo remote).
  5. Press the same button on your old remote (eg. POWER button on my old tv remote control). When the jumbo remote's light changes from rapid flashing to slower flashing, press ENTER on the jumbo remote.
  6. You're done! Try the jumbo remote out (eg. Aim the jumbo remote at your TV, press the jumbo remote's TV button, then press the jumbo remote's POWER button). Your television should turn on or off with your jumbo remote.
You can program any jumbo remote button this way (eg. MENU, EXIT, MUTE). Just make sure you press the same button on each remote in steps 4 and 5 (eg. MENU on jumbo remote, MENU or LIST on old remote).
Top One For All Televison & Video Experts
Sudeep Chatterjee
Sudeep Chatterjee
Herb Box
Herb Box
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
