SOURCE: U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
SOURCE: Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
SOURCE: Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
