Slide the middle left switch to TIME SET. Use the DAY, HOUR and MINUTE buttons to set the current day and time.
Slide the middle left switch to PROG.
When you set the switch to PROG, the number on the right on the LCD display will be a 1, and it will say ON above it. Adjust the DAY, HOUR and TIME for when you want your first program to turn on. Then press the bottom left EVENT button to proceed to set the OFF time for program 1. Adjust the DAY, HOUR and TIME for when you want your first program to turn off.
Press the bottom left EVENT button to move on to your 2nd event, and set the ON time. Again, press the bottom left button to move on to your second event OFF time. Continue in this way until you have programmed up to six different ON/OFF events. When you have programmed as many events as you need, slide the middle left switch to RUN at the center position.
To use the timer now, slide the upper left switch to AUTO at the middle position. The upper left switch, when moved to the right hand AUTO RAND position, will run the programs, but randomly start and stop them within a half hour of their programmed settings.
To use the timer manually, slide the upper left switch fully to the left to MAN, and press the bottom left switch to cycle between ON and OFF.
Intermatic does not have HB71R instructions.
On earlier post, I offered instructions for HB77R, and asked for more information and feedback, but simply got a downvote and no feedback.
If somebody would add a comment and say exactly what buttons are on this timer, and say what they remember or know about this timer, I might be able to put together the instructions.
