Canon CLC 1150 Color Copier Logo
Posted on Oct 24, 2010
I have a CLC 1150 with an error code E008 0000 it keep telling me to switch unit off and then back on. But the error code returns each time. Is there a code to enter that will clear the error code?
5 Related Answers
Anonymous
  • 62 Answers
  • Posted on May 21, 2007
SOURCE: clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
ramstp
  • 4 Answers
  • Posted on May 07, 2008
SOURCE: E072 - 0002
most of the time if you replace the transport cleaning unit it fixes the fault. on one machine i had a break in the wire lume that caused the problem. also make sure you don't have a piece of paper jammed in the unit.
Anonymous
  • 168 Answers
  • Posted on Dec 29, 2008
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
color_50
color_50
  • 22 Answers
  • Posted on Mar 14, 2009
SOURCE: Canon CLC 1150
Check the Delivery Door Switch SW5/ Also check AC Relay near power cord Assmbly=check contacts clean if dirty
montero
  • 5 Answers
  • Posted on Feb 11, 2010
SOURCE: Canon CLC 4000 Error code E013-0002
DESCRIPTION:
THE WASTE TONER LOCK DETECTION
SWITCH (SW4) HAS BEEN PRESSED FOR O.1 SECONDS OR MORE.
Solution: the waste toner is FULL.you have to get rid of that TONER.
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
