Hello, I just figured out what Error Code 81 means in the Lavazza LB2210 espresso machine. This code indicates a jam in the cup mechanism. To fix this issue you just need to remove the front cover (remove two screws) and then look for any jams in the roller section of the unit located in the center. In my case the cup was jammed at the upper left section of the roller mechanism that is used to eject the cups. I had to pull out the used cup and then reassemble the unit (at which point everything was fine).
This issue happened despite the use of Blue cups so if you see this message you should look for a jam to clear.
This helped me fix mine thanks. After removing the front panel and locating the jammed capsule in the top left you should place the waste drawer back in and turn the machine on. This moves the capsule loading arm back momentarily and you can pluck out the offending capsule. Be careful with the electronics though although that section does not have any exposed wires.
which 2 screws?????
