Hi ya
remove your R4 card. Go to the system setting and turn your date on the dsi back by a year!!
Put your R41 back in and it should work.
happened to my sons and the only way it would work was to turn the date back.
my grandsons r4i went wrong last august didnot get any help from the supplier they dont worry it was thier pocket mone IT COST £60 THANKYOU SO MUCH my grandsons are delighted i am happy i never thew it in the bin thanks again
Thank you x so much, thought i would have to wipe everything off, downloads loads of things and spend hours trying to fix it x thanks x
Bingo! Yesterday (31/April) I was doing a Google search on the R4i "System Date
Error" problem and found the permanent solution! Basically one that
DOESN'T involve changing your system date to one that it's not! Check
out this blog post:
http://www.nds-gear.co.uk/blog/2010/05/nds-gear-solves-r4i-sdhc-system-date-error-problem/
Follow the instructions and use their software (for genuine R4i-SDHC
cards only of course) and problem should be solved! Worked for me on a
regular DSi console with the original R4i SDHC card, 4GB memory.
My R4i card no longer works after DSI software update?
Reset DSI to factory settings but no joy with R4i card, message - "an error has occurred...."
SOURCE: Message " System date error! Please check NDS system date"
I read that changing the date to 28.09.2009 should work, as this happened to me today too... and it worked. Very weird, but try it anyway :)
McPay
SOURCE: system data error!Please check NDS system date.DS lite will not a
this happened to me. all you have to do is take the card out, go to options, click on the calender and set it back a year. thats what i did and i fixed it.
i hope it workes for you too.
Strange but this does work, putting the date back one year fixes the problem. excellent !!!!!!!!!!!!!!!!!!!! (thank you)
SOURCE: DSi system date error please check NDS system data
out this blog post:
I did have this problem to I have put the card out and than i did go to the calendar and put it back a year and than i turn it of and insert the card back and turn the ds on and than it has WORK so simple like that.
