GE JTP15 Electric Single Oven Logo
Posted on Mar 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F5 Error - GE JTP15 Electric Single Oven
Michael Thomas
Level 3:
  • GE Master 3,056 Answers
  • Posted on Mar 29, 2010
Michael Thomas
GE Master
Level 3:
Answers
3056
Questions
52
Helped
1338861
Points
10936
Hello there:
this f-5 error normally stems from 2 things:
F5 Element relay enable on. (STUCK CLOSED) Replace the electronic range control (ERC)and check the door switch assembly for continuity if bad replace
How can I turn back my Frigidaire oven that has an error of F5 on its electrical panel please?
Question edited for typos. However "turn back"??
Frigidaire Error Codes
Error Code: F0, F1, F5, F6
  • Code Description: Electronic oven control failure
  • Solution: These codes indicate a malfunction in the electronic oven control. The electronic oven control (EOC) may also be referred to as circuit board, control board, mother board, ERC, or clock. Unplug the appliance for about 10 minutes to see if the error code will reset itself. When you reconnect the power, if the error code is still displayed, you can test the temperature sensor with an Ohm meter to determine if it has the proper level of resistance. If the oven control is failing or defective, replace it.
Also says Relay Board fault
https://www.google.com/search?q=Frigidaire+oven+error+of+F5
Oct 25, 2022 • Ovens
1helpful
F5 error code
F5 = EOC electronic control failure replace electronic control is stated in the service manual. If you have any further questions message me them back. Thank you
Rick
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
3helpful
2answers
Error code F3 and F5
Hello there:
Here is the code for these 2 codes hope they are very helpful for you
F3
Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
1helpful
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Thank you for using FixYa.
9helpful
E1 F5 error message when try to activate the self clean
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
4helpful
2answers
Whirlpool accubake oven error code
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
It may just be a door switch
6helpful
2answers
The F5 error code?
I unplugged the oven and it cleared the code and was able to self clean the oven.
2helpful
E1 and f5 error
Top GE Ovens Experts
Paul Bade
Paul Carew
Are you a GE Oven Expert? Answer questions, earn points and help others
