VinoTemp VT-60 Wine Cooler Logo
Posted on Feb 18, 2010
Error code 88 - VinoTemp VT-60 Wine Cooler
Samsung rb2055sl reezer issue.
88 on its own is a Samsung code.
Did you check the evaporator coils at the back of the freezer. It the defrost timer, or the heater fails, if forms a large block of ice and there is no airflow.
https://all-errors.com/samsung-refrigerator-error-codes-88/
https://www.google.com/search?q=Samsung+RB2055SL+code+88+8
Model no. 7468 when winding bobbin, machine stops and flashes code 88. why is it doing this
Check the troubleshooting section of your owner's manual. Usually, it will have a list of more common error codes.
You can also search for the
make + model + "error code 88"
or contact the manufacturer.
8 e code
Most like it is a defrost sensor error in the FF section. On the back of your refrigerator there should be a schematic of what happens when there is an error...normal when performing the self test and all is ok is a reading of 88 88 Different parts of the 8 will blink depicting the error. For 88 88...if the last 8 is blinking the sections on the right side of the eight it looks like an E...but it is not.,..it is blinking an R1 b, or R1 c error. Looking at the chart R1 b is Sensor System in FF Compartment Errors, and R1c is Defrost Sensor Error in FF Compartment Errors.
I hope this clears things up as I see a lot of people say there panel is flashing 88 8Y, or 88 8E when actually it is just different parts of the 8 blinking.
10helpful
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
1helpful
What does the error 88 code mean
88 is not an error code. This means filter only
Error 88 typedrive not connected
Tapeware error 88 refers to a tape drive not being found. Make sure you have disabled removable storage in services. What tapes are you using?
you can find your tapeware error codes by going, Start/Programs/Tapeware/Tapeware Documentation/printable documents/Tapeware error code reference
5helpful
My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
3helpful
3answers
DFI LanParty DK 48 Motherboard, LED Error Code: 88? Does not boot, LED displays 88.
From the manual - Code 88 is "There is no "88" definition on the Award BIOS code. (BIOS program executed the wrong process therefore showing the wrong POST code.)
1 of 2 problems:
1. The BIOS - Mixed-up BIOS data, which is fixed by resetting CMOS information
2. MB is defective. (NB chip may be defective.), which you have to RMA to manufacturer
Top VinoTemp Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
Larry Ng
Larry Ng
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
