Dryers Logo
Posted on Jan 02, 2010
Electrolux dryer error code e63 - Electrolux Dryers
  • Anonymous Mar 24, 2014
    What is Electrolux Dryer Code E63
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22556
Points
8
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Anonymous
Level 1:
New Friend:
  • Posted on Dec 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22556
Points
6
E63 is .....Heater to Earth Ground
Heating element or wiring defective
Check heater coils and connections for short circuits to the cabinet. Replace
heater and/or wiring and retest... Regards
Ron Mortellito
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 12, 2019
Ron Mortellito
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
24063
Points
7
This happened to me because I had one garment in the dryer and had it set to normal heat. The lint trap was clean and no other issues contributing to overheating. Solution: breaker 1. Open the door (it pops open in this condition anyway) 2. Wait 10-15 minutes for it to cool down. 3. Kill power for a few seconds (Pull plug or cycle breaker) 4. Run for 10-15 minutes with heat set to AIR ONLY. This fixed my problem.
2 Related Answers
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jan 15, 2011
SOURCE: What is Electrolux Dryer Code
Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with, check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Sep 25, 2009
SOURCE: Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Top Electrolux Dryers Experts
vince
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
