Posted on Jan 02, 2010
I use print direct from vb.net code to printer HP DeskJet F2410, it will take a few minut to printer ... What wrong and how to solve?
5 Related Answers
Anonymous
  • 425 Answers
  • Posted on Nov 05, 2010
SOURCE: My hp deskjet f2410 printer
Hi, do not have the part numbers handy, but there are 3 small white gears which need to be replaced after you remove the fuser. You can contact metrofuser.com as they have a kit for less than 10.00 that contains all 3 gears. Just tell them you have the f2410 gear noise problem.
This problem can happen because of following reasons :
1. There is some piece of paper / paper clip / sticker stuck inside printer and you are not able to access it. In this case you need to remove all ink cartridges, turn off printer, then turn it upside down and shake it few times. If still not working then you need to open it up as much you can to see if something is stuck
2. Also, you should open up the printer and blow air in it (using compressed air can) to remove all dust. Then take few drops of oil and apply it on the main shaft on which the carriage moves horizontally.
If above doesn't help then the problem is worned out rollers and they need to be replaced. But HP doesn't sell these rollers and there is no set of rollers available that you can buy all together.
You will either have to send it to HP which will be not cost effective or take it to local repair shop. Else you will have to buy those rollers individually from some online store or local store.
Feel free to ask any question or concern you may have. I will be glad to help you.
Thanks for using fixya..
Anonymous
  • 111 Answers
  • Posted on Jan 03, 2011
SOURCE: my printer hp deskjet f2410
1.Check if there is low ink level in cartridge
2. Check if there is any piece of paper stuck inside
3. Unplug the power cord while its ON , Press and hold OK and CANCEL at the same time, while holding them plug in the power cable and then release the buttons.
It should fix the problem
Anonymous
  • 117 Answers
  • Posted on Feb 01, 2011
SOURCE: hp deskjet f2410 installer
The installation software for the HP Deskjet F2410 printer can be found at the following site,
http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
When you arrive at the site, input your printer's model number (f2410), into the block marked,
" for product" and click the arrow, you will then be guided to the drivers for your printer.
You should be happy with the results.
Anonymous
  • Posted on Feb 06, 2011
SOURCE: MY HP F2410 PRINTER BLINK
printer utha k chaat say neechy phaink do theek ho jaye ga mainy b aysa he kiya hai ...
Anonymous
  • 111 Answers
  • Posted on Apr 07, 2011
Unplug the power cord from the back of the printer while its ON
now Press and Hold
Ok and Cancel button at the same time
While holding them plug in the power cord
Once the printer turns on release the buttons
You will see the Reset message on screen of your printer and in the process it will align the cartridges
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
