SOURCE: three-digit code for prima tv for universal control
If you can't find it under prima look under legend
If not read your manual and depending on the remote you have a option for the remote to find the code by itself
Just have to follow the instuction in the remote user's guide in the place that says "Brand not listed"
Good Luck
-John-
SOURCE: Universal Remote Codes
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes the direction to forward again.
5. Press and release MUTE to install the code.
SOURCE: need samsung CxJ1952 universal remote code
Can anyone pls help me with the universal code of Samsung CXJ1952.
