Computers & Internet Logo
R
Rasit girgin Posted on Feb 08, 2018
I have a Fujitsu split system. 2 years old. I could not start it. As if power is not connected. I turned off and on the main switch it is not starting again.
May be it is a reset issue
5 Related Answers
Anonymous
  • 1239 Answers
  • Posted on Sep 12, 2008
SOURCE: Hi,Ihave a hoover hnf 7167
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt. To remove the belt:
Step 1: Loosen the bolt on the motor bracket and move the motor to put slack in the belt.
Step 2: Remove the old belt and stretch a new one into place on the pulleys.
Step 3: To put tension on the new belt, use a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. The belt should have about 1/2 inch deflection when you press on it at the center point, midway between the pulleys. If the belt is too loose, it will slip on the pulleys, causing the machine to malfunction. If the belt is too tight, it will wear very quickly and will probably become so hot that it will start to smoke or smell.
Loose pulleys can also cause problems. Most pulleys are fastened to shafts with setscrews around the hub of the pulley. These screws must be tight or else the pulley or belt will slip. The resulting malfunction may seem to be caused by a faulty motor, but it can be corrected by tightening the pulleys and adjusting the belt. For this reason, always check the belts and pulleys before working on the motor.
thank u................
Anonymous
  • 3 Answers
  • Posted on Feb 01, 2009
SOURCE: evaporator vibrates and a noise and air gets hotter
When was the last time you cleaned the washable filter located behind the front flipup door of the unit? All mini-split systems are notorius for having dust build up on the blower vanes and as it runs it pulls humidity out of the air causing that dust to become like a past e
and changes the angle of attack on the blower cage. Check your filter and take some compressed air and blow it out real good and see if that helps.
Anonymous
  • 17 Answers
  • Posted on Sep 22, 2009
SOURCE: Panasonic dlp new bulb clean filter error message reset info not
For the Air Filter message, the filters are located inside the unit, if already cleaned, perform a reset of the unit, Press Hold, VOL - on set and TV/Video on remote for about 5 sec. If a Lamp timer reset message, try VOL - on the set and Mute, Move or PIP on the remote (try all three)
hunter19_46m
Curtis Sewell
  • 7482 Answers
  • Posted on Dec 30, 2009
SOURCE: the dryer is going Ka-Boom, ka-boom over and over
I would fix the machine if everything else is working on in. Your problem sounds like drum rollers have flat spots on them or in need of lubrication. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Testimonial: "Thanks for the help, I'll give it a try and report back after the weekend!"
Anonymous
  • 308 Answers
  • Posted on May 07, 2010
SOURCE: my fujitsu split system blows warm air after about
There is not really enough information here to properly answer your question. I can make a couple of observations for you though. 1. Compressor, yes this could be the problem, but it is not quite that simple. Is the compressor running when the hot air starts to blow? 2. Capacitor, no I don't believe this is the problem, as if it were a capacitor problem, chances are the unit wouldn't even start. 3. Gas leak, again no, if it were a gas leak, then you wouldn't get an hour of good run time when the unit starts up, repeatedly. Hope this helps.
Testimonial: "very helpful n my question answered based on the info given. "
Top Fujitsu Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
