Home Security Logo
D
Deborah irvine Posted on Jan 24, 2018
What does e-run mean can't lock safe
Sentry safe
  • Terry
    Terry Jan 24, 2018
    Hi Deborah irvine, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What is the model, or model number? How to identify the model number is shown with pictures at this link.
    https://www.sentrysafe.com/support/find-...
  • Terry
    Terry Jan 24, 2018
    Pictures of how to change the batteries on different models at this link: https://www.sentrysafe.com/support/faqs/...
5 Related Answers
Anonymous
  • Posted on Dec 26, 2008
SOURCE: new safe # CW3607 Sentry Safe will not lock
Thank You problem solved
tmburke
  • 76 Answers
  • Posted on Jul 02, 2010
SOURCE: Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool: lost key: Sentry 1100 strong box....
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
A1 Locksmith Burlingame
  • 170 Answers
  • Posted on Aug 09, 2010
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
Anonymous
  • Posted on Aug 10, 2010
SOURCE: I can't open my Sentry Safe (model #2100)
The problem is in the latch so one solution is to sit on the box, squeeze the latch and it opens. Voila!! Stupid R&D!
hichbiri
Huseyin Huseyin
  • 3469 Answers
  • Posted on Jun 23, 2015
SOURCE: How can I open the safe lock if I got only the key? Sentry safe lock
call in a locksmith, could be very expensive. Cut it open, could be ridky to contents.
Top Sentry Home Security Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
