Frigidaire ATF6000ES Front Load Washer Logo
A
Anonymous Posted on Feb 17, 2015
How do i remove the loc code - Frigidaire ATF6000ES Front Load Washer
  • Official Brand Answer 2,267 Answers
  • Posted on Feb 25, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1313570
Points
2558
I appreciate your post, friend!
Based off the information you have provided you are receiving a "LOC" code on your Frigidaire washer. "LOC" typically means that your control lock feature is on to remove the lock feature you need to hold down the options and select buttons for ten seconds. I hope this is helpful. -Matt
LOC code will not do anything
OK I HAVE the solution...You have to reset/Delete all the data..codes. Your LOC(KED) out! Got It? I have to post the web site because the process is detailed, but easy to follow. Go the web site I posted. It is a PDF document and then go to Page 5. Good luck!
Redirect Notice
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Whirlpool loc
From a google search the following is copied:
LOC is a control panel lock not a door lock, see below.
The Control Lock shuts down the control panel pads to prevent
unintended use of the ovens.
When the control is locked, only the CLOCK, TIMER SET and
TIMER OFF pads will function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Before locking, make sure the ovens,
Timer and Timed Cooking are off. Press and hold START/ENTER
until a single tone sounds and "Loc," a picture of a lock and
"START?" will appear on the oven display, about 5 seconds.
Repeat to unlock and remove "Loc" from display.
If the above does not work have you tried removing power from the uit for a few minutes to see if it will reset.
________________
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/499415-whirlpool-double-oven-shows-loc-display.html
Jan 26, 2018 • Ovens
I have 2 Chevrolet 1500 trucks and 1 radio dont work when i swapped the radios it has LOC on the screen how can i remove the LOC? If its a code to unlock it how can i get it?
on a 2003 you have to have it unlocked at the dealer, it thinks someone tried to steal it, and doesn't recognize the vehicle its installed in
43helpful
What does the code LOC mean?
HI. This is a simple lockout feature that will allow you to prevent accidental starts or stops when children are present. It can be initiated by pressing the Options and Select buttons at the same time for ten seconds. This will initiate the lockout feature and the letters "LOC" will appear on your display. To remove the control lock out, simply, press the Options and Select buttons together once again at the same time and hold them for 10 seconds. This will release the lock out and the letters "LOC" will disappear.
2answers
1997 bonneville has LOC on the radio, How do I clear it?
if you dont have the code, the radio has to be removed and a gm dealer can get the code.
My radio says loc????
its in "safe" mode, remove all power for 15-30 mins. You might need a code to turn it on.
After changing my battery my rado shows LOC on the display. I didn't have the code when I bought it my chevrolet venturra 1997. Please help me
you will have to take the vehicle to the dealership for them to unlock your radio. for those radios the loc feature should be something that the user sets and is only active when power is removed but can by undone by the dealer they usualy do not charge for this.
Top Frigidaire Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
