Televison & Video Logo
A
Anonymous Posted on Oct 20, 2014
How do I stop the green light from flashing Sharp 46 aquos
Jayesh Panchal
Level 2:
Sergeant:
Champion:
  • Sharp Expert 280 Answers
  • Posted on Nov 28, 2014
Jayesh Panchal
Sharp Expert
Level 2:
Sergeant:
Champion:
Answers
280
Questions
0
Helped
127295
Points
621
Remove Main's plug press Input & Ch.Down button from LCD and put Main's plug to start LCD.
You will get K on Screen press Vol - & Ch- from LCD
You will get 1/10 page go to 9/10 by pressing ch.- button
You will get EEP off screen press ch- button from remote and press
Right side arrow from remote and press OK
On screen you will get EEP running.
After finish this oprestion remove plug and restart LCD.
5 Related Answers
Anonymous
  • Posted on Jan 21, 2009
SOURCE: Sharp Aquos wont turn on
We were watching our TV and suddenly the picture went out. We still have sound. This is true with any device hooked to the TV as well....sound but no picture.
Anonymous
  • 6 Answers
  • Posted on Sep 03, 2009
SOURCE: Sharp Aquos 32 wont turn on
I called up Sharp, and if you are a part of Sharp AQUOS Advantage Program you get free in home service.
They were very nice about it, and I already have a technician coming to my house on Saturday and I called on Wednesday.
I doubt Sharp's policy alot less now!
Anonymous
  • 148 Answers
  • Posted on Feb 03, 2010
SOURCE: Sharp Aquos LC30HV4U stopped working
You are in luck!..The units poowerboard is overheating and since you have it taken apart already this is the fix for you!...Check the popped capacitors in the metal box you find on the back of the actual screen inside the unit...This is a very common problem,m so I've helped many this way and wrote a general post on the how to's of diagnosing and repairing the problem, follow these steps and your tv ill be good as new for less than $5.00 before feb 5 th!! :P...Here it goes (please rate if this works out :D).....................The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
If this has helped anyone (or not) then please rate, thank you!
Anonymous
  • Posted on Jun 04, 2010
SOURCE: sharp 46 aquos model LC46E77UN tv turned off power
Unplug it hold down the Channel Down button and the Volume Up button unplug it for 10 seconds then plug it back in and continue holding them down for another 10 seconds then release. I had the same issue and this fixed it now I have another though *~*
Anonymous
  • Posted on Feb 24, 2011
SOURCE: LC-C6554U HDTV AGUOS 2 GREEN LIGHT FLASHING, NO PICTURE NO SOUND
Did you ever find a solution to your problem? I have the same set doing the same exact thing.
Thanks
Top Sharp Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
