Computers & Internet Logo
Julie Clark Posted on Aug 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memory how much memory can it hold/
Wale Sarumi KomputerSolution
Level 3:
  • Master 6,993 Answers
  • Posted on Aug 22, 2014
Master
Level 3:
Answers
6993
Questions
Helped
1726621
Points
1262
please give me the processor info and hard disk size, so i can tell you how much memory it can hold.
Regards.
How do you clear the memory for a ReliOn blood pressure monitor model 144-245-001?
Hold down the Memory button first and press the On/Off button while holding down the Memory button.. you will have to repeat this for both Memory A Button and B button.
1helpful
IS THE A215-S5802 CAN UPGRADE THE MEMORY FROM 512MB TO 1GB FOR 2 SLOT
Your Toshiba Satellite has 2 memory slots and will hold a total of 4GB (each slot can hold 2GB). It uses DDR2 PC2-4200 or DDR2 PC2-5300 Memory chips.
Below is a link that gives all the info and prices from 4 All Memory.
http://www.4allmemory.com/memory/toshiba-other-a215-series/
How to add or change DDR2 Memory Compaq Presario SR5110 desktop computer
Just remove the power cord, open the case, turn the computer on it's side and you will see the memory sitting in the slots. Push down on the latches on both ends of the memory slot and then you can pull the memory out.
Be sure to replace it with compatible memory or it will not boot up. Also it you install more than your system will hold, it will not register the excess.
Try 4 All Memory website. It will tell the type, how many slots you have and the maximum amount of memory it can hold.
It looks like your system uses DDR2-PC2-5300 Memory. It has 2 slots and a total capacity of 4GB which means each slot can hold a 2GB chip.
http://www.4allmemory.com/memory/compaq-hp-presario-sr5110nx/
Car deck memory issue
Is the fuse blown on the memory wire from the decks wiring harness. Also, makes sure memory wire and accessory wire are not flip flop.
2helpful
How do you clear the memory on model # 271245 (38W1-A)
Push and hold MEMORY key. While holding this, push and hold the SET TIME/DATE key. You will see a message. Let go of the keys. The memory is clear.
2helpful
Any idea hw to restore psp games
Backup up your games on a PC. Then Format your memory stick and put the psp games back in the memory stick if this does not work try formatting your psp by entering the recovery mode HOLD R + HOLD POWER...
Go to advanced/advanced config/format flash 1 and reset settings
if this also fails try using another memory stick on your psp
2answers
How to program speed dial on T7208 telephone?
Programming
memory buttons
External autodial
1. If you are on a call or an open line with dial tone, press Hold
or Rls
2. Press Feature * 1
3. Press a memory button.
4. Dial the external number.
5. Press Hold to store the number.
6. Label your new button.
Internal autodial
or Rls
2. Press Feature * 2
4. Dial the internal number.
5. Label your new button.
Features
or Rls
2. Press Feature * 3
4. Press Feature and the feature code.
Erasing memory buttons
or Rls
3. Press the memory button you want to erase.
4. Press Hold to erase the button.
My camera and memory card aren't holding very many pics
need more info but usually ir means the memory is full . or the memory card is corrupt. i suggest saving all the pics to your computer then try reformatting the memory card. you can usually do this from the camera itself. you will have to go thru the cameras menu and pick delete all pics and format card.
also check what pixel setting you are using. the higer the pixel setting the lass pics the memory will hold.
however lowering the pixel rating also reduce the quality of the pictures. hope this helps .
4helpful
Hi. i cant get the sound to come through continuosly when using the kaoss pad, only when i put it on hold. is there a way round this?
You need to put the Mini Kaoss Pad in direct mode.
Hold down Memory A and press Memory B once, use the dial to select DIR instead of SND.
Hold down Memory A and press Memory B once again to return to normal play mode.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
