Cameras Logo
A
Anonymous Posted on Jul 04, 2014
Why does my camera display 'Out of Memory'?
I emptied the files and it worked for one picture then 'out of memory' showed up again.
Bart Pulverman
Level 2:
Guru:
  • Nikon Expert 362 Answers
  • Posted on Jul 27, 2014
Bart Pulverman
Nikon Expert
Level 2:
Guru:
Answers
362
Questions
0
Helped
87158
Points
625
Your camera comes with a very small internal memory. Your camera may be telling you your memory is filled up because it is. First, if you do not have an add-on SD memory card for your camera, get one and install it following your camera's instruction manual. Second, if you already have an SD card installed or you put a new one in, go to your camera's menu. There will be an item that allows you to use either the camera's internal memory or the add-on memory. Make sure the add-on SD card is selected.
5 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 17, 2007
SOURCE: Memory Problem
May was a long time ago - you may have solved this by now...
A330 cameras only accept certain types of xD cards.  If you have a type 'h' card, it won't work.
I have a card that says "H512mb" and it's useless.  You can only use cards with no letters before the card size or type "M"  cards.  With a type "M", you need to upgrade the camera firmware.  Read directions here: http://www.fujifilm.com/products/digital/download/a330/fupd.html
-Kelly.
Cindy lou wh
  • Posted on Jun 15, 2008
SOURCE: File error
I take a picture and go back to view it and file error shoews up. Can those phtos be retrieved?
pontelemon
pontelemon
  • 538 Answers
  • Posted on Mar 25, 2009
SOURCE: internal memory full ??
In the settings switch from internal mem. to the card
Anonymous
  • 919 Answers
  • Posted on Apr 28, 2009
SOURCE: Memory full; how to clear
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the internal memory and then you will be able to use it again. To format the memory: Remove the xD card from the camera - Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the memory so it can be used again.
Anonymous
  • 11967 Answers
  • Posted on Jun 30, 2010
SOURCE: DMC-FX55 memory problem
Press menu/set...playback menu....select "copy" Make the choice to copy the internal memory to the card and select "yes".
Top Nikon Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Are you a Nikon Camera Expert? Answer questions, earn points and help others
