Casio EXILIM  Card EX-S770 Digital Camera Logo
Posted on Nov 06, 2007
Camera keeps resetting the settings when turned off
Everytime I turn the camera off and then back on it asks me to select the Language, Home City, DST, Date Style, Date and Time. It also resets all of the other settings. After I set everything and turn it off, the same thing happens again. It has been fine this whole time and just started happening last week. Any idea why or what to do to fix it?
  • 6 more comments
  • glezfco Nov 07, 2007
  • Anonymous Nov 08, 2007
    im having the same problem, ive tried everything. anyone have any advice or tips
  • spinnerex Dec 01, 2007
    I sent mine in to Casio to get it fixed..
  • Anonymous Dec 08, 2007
    I have exactly the same problem. Everytime I turn the camera off and then back on it asks me to select the Language, Home City, DST, Date Style, Date and Time. It also resets all of the other settings. After I set everything and turn it off, the same thing happens again. It has been fine this whole time and just started happening on 7 Dec 07. Any idea why or what to do to fix it?
  • raymond2stl Jun 06, 2008
    I've had the same problem for about 2 months. Seeing as how I was desperate to fix my camera, I followed the instructions below...and as warned....I now get a "system error" whenever I try to turn it on. So...my camera is screwed.
    So...I recommend unless you have someone who knows something about cameras with you...don't follow these instructions.
  • betsymc Aug 31, 2008
    I have the same problem - happened about 2 months after I bought it, so I sent it for warranty repair. It was fixed, but behold, about 4 months later, it's doing it again! I HATE CASIO! I've only had this camera less than a year, and I'm ready to ditch it! I'm afraid to try the solution below, since the camera still works, it's just to get thru the menus, all my pictures are dated 1/1/2006 with 00:00 as the time (annoying).
  • sweetsinger May 13, 2009
    i HAD the same problem, so i followed the advice below.
    this just broke my camera.
    don't do it.
    now it's completely unusable.
  • zgr Saglam
    zgr Saglam Jul 24, 2014
    Try this method..I fixed my camera right now!! Solution is firmware update. Follow under link,http://support.casio.jp/download.php?cid... 1. download this file EX-Z70_101.exe. 2. open new folder under C: 3. exract it 4.Connect your camera to computer through USB cable or sdcard 5. Copy EX-Z70.bin file to camera memory or card 6. Hold down the [MENU] button as you press the [POWER] button to turn on the camera. Keep the [MENU] button depressed until the message "PROGRAM UPDATE" appears on the monitor screen 7. hit YES 8. wait when its complete 9.After installation is complete, turn off the camera. 10. First power on setup date and time 11. Enjoy Regards from Turkey Ozgu
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Dec 15, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1643
Points
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
  • Anonymous Dec 15, 2007
    I do not know, it is your responsibility, to apply this possible solution. I have found this by the Internet network.
    I have read in the FAQ of Casio, this problem is possible to have to
    that the battery is damaged, to prove with a new battery, and if the
    failure persists, to prove anybody this solution that I propose, YOU DO NOT ACT IN THE REST OF THE MUNU OF TEST
    Never perform the menu items unless otherwise instructed. Doing so may cause destruction of the data inside, which will make the camera unusable.
    To boot the test mode:
    1. While firmly pressing down both [BS], [PW ON] and [UPPER], turn the power on.
    2. After the version appears, press buttons in the order of [DOWN], [DOWN], [BS] and [MENU] in 0.5
    second. The diagnostic menu appears.:
    1 :VERSION I N F O
    2 : U S B T C C T E S T
    3 :ROM UPDATE
    4 : L A S T MEMORY
    5 :FORMAT
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1579
Points
I've had the exact same problem for months now and i was playing around with it just then and i fixed it!
all i did was go into menu and then into set up, the very last option here is reset. after you say yes to resetting it will ask you to set the time and date then once you do this you are free to turn the camera on an off without it asking what language you speak :)
Anonymous
Level 1:
New Friend:
  • Posted on Jul 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1579
Points
I had this problem too and following the instructions in Solution 2 (emilyjreece), it seems to have fixed it. I hit the menu button, went to the Set-Up tab, hit Reset and then Reset again.
Turning the camera off, then back on, it asked for the date (not location this time) and now it seems fine.
Haven't had the problem since.
I hope this helps people.
zgr Saglam
Level 1:
New Friend:
  • Posted on Jul 13, 2014
zgr Saglam
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3454
Points
Hi everyone,
http://support.casio.jp/download.php?cid=001&pid=385
3. exract it
7. hit YES
11. Enjoy
Regards from Turkey
Ozgu
Anonymous
Level 1:
New Friend:
  • Posted on Sep 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1579
Points
I thought I ruined my Casio camera after continuous use and dropping it over the past 5 years. Never had a problem until I charged the battery in another country using an adapter. After charging the battery I encountered this very problem.
1. Remove the SD card
2. Turn on the camera
3. Set the location, date, and time
4. Take a photo, any photo will do (leave the camera on)
5. Go to the menu screens
Top Casio Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
Rommel Balcita
Frank Fernandez
Are you a Casio Camera Expert? Answer questions, earn points and help others
