Kyocera 302GR94123 3050 4050 5050 PWB Main Assy Logo
A
Anonymous Posted on Apr 26, 2014
Keyocera 3050 error code c0060 - Kyocera 302GR94123 3050 4050 5050 PWB Main Assy
1 Related Answer
Anonymous
  • 3 Answers
  • Posted on Feb 04, 2009
SOURCE: keyocera 1820 balck & white copier error code C6400 on start up,
Zero-crossing signal problem
The engine PCB does not detect the
zero-crossing signal for the time specified
below. At power-on: 3 s Others: 5 s
That is what the code means in the service manual. However you can try a reset by doing the following. Press 10871087 to enter maintenance mode. Once in maintenace mode press 906 then follow the steps below
1. Press the start key.
2. Select the EXECUTE using the up/down cursor keys. It is displayed in reverse.
3. Press the start key to reset partial operation control. The maintenance mode is exited, and the machine
returns to the same status as when the power switch is turned on.
If you do not feel comfortable performing this operation, or the problem persists then call a technician immediately.
Top Kyocera Office Equipment & Supplies Experts
George Mclaughlin
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
