Microsoft Windows Vista Ultimate Edition Logo
A
Anonymous Posted on Apr 22, 2014
KERNELBASE.dll Problem signature: Problem Event Name: APPCRASH Application Name: WindowsFormsApplication2.vshost.exe Application Version: 11.0.50727.1 Application Timestamp: 5011d445 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.17514 Fault Module Timestamp: 4ce7b8f0 Exception Code: c0020001 Exception Offset: 0000b760 OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: a661 Additional Information 2: a6619d95977b32c6f39ca29414741f47 Additional Information 3: 347a Additional Information 4: 347aa39345bbe0c1e1f3b225c3d4a939
3 Related Answers
Anonymous
  • 846 Answers
  • Posted on Apr 13, 2009
SOURCE: Problem Event Name: APPCRASH
try this
http://www.microsoft.com/downloads/details.aspx?FamilyID=b0c7136d-5ebb-413b-89c9-cb3d06d12674&DisplayLang=en
Hope It Solved Your Problem
Good Day
Anonymous
  • 9 Answers
  • Posted on Feb 01, 2010
SOURCE: Problem signature: Problem Event
Try this
  1. Go to the Control Panel and click Printers
  2. Right-click on the white space and click "Run as administrator > Server Properties"
  3. Click on the "Drivers" tab, click on the offending printer and click on the "Remove" button.
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
Anonymous
  • 4961 Answers
  • Posted on Jul 24, 2012
SOURCE: Problem Event Name: APPCRASH Application Name: Explorer.EXE Application Version: 6.1.7601.17567 Application Timestamp: 4d6727a7 Fault Module Name: ntdll.dll Fault Module Version: 6.1.7601.17
You have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
APPCRASH
this info does not say which app crashed, so you have to give more information about what you are doing before this happens, what you are trying to do. it says it is in the Kernelbase but that means your system OS has a problem. if this happens when you are trying to start your PC then it is a major problem and you might have to restore your OS or reinstall it if restore cannot be ran from backup.
to be sure, would have to know what happened before this happened...what you were doing, if there was a blue screen crash, virus attack, etc. thanks
You could uninstall unzipexpress and install winrar or winzip.
1helpful
Problem Event Name: APPCRASH Application Name: SBUpdate.exe Application Version: 1.0.3.4
What software by Speed Bit do you have? DAP? The Speedbit updater failed to respond. Go to Speedbit and reinstall: http://www.speedbit.com/video-downloader-converter/
Visio APPCRASH
Do one one thing Right Click on Your Root Drive(C Drive )go to properties, there you will find option Called Tools, click it. and check for disk error by clicking scan for error and scan for error.
it'ss ask you for shedule scan so restart the computer and let it scan at startup.
Hope this will work for you.
3helpful
2answers
Please try disable the Data Execution Prevention(DEP) or add the Yahoo messenger.exe in Data execution protection (DEP) exclusion list. This error is comming because you have enabled DEP. I think it will help you to fix the issue.
Thanks for joining Fixya community...Good Luck
Uninstall and re-install...see if that helps.
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
