NEC ETW 16DC-1 Corded Phone Logo
Posted on Jun 12, 2009
What is the function of NEC - NEC ETW 16DC-1 Corded Phone
NEC Inforntia DX2ET 32 BM (caller ID function not working)
To restore the caller ID function on your NEC Infrontia DX2ET 32 BM PABX system, you can follow these steps:
Check the configuration settings: Ensure that the caller ID feature is enabled in the system configuration settings. You may need to consult the manual or a professional to assist with this.
Check the phone lines: Make sure the phone lines are properly connected to the PABX system and are functioning properly.
Check the firmware: Make sure the firmware on your system is up to date and compatible with the caller ID feature. If not, you may need to upgrade the firmware.
Test the caller ID function: Try making a call from an outside line to the PABX system and see if the caller ID is displayed on the phone. If not, try using a different phone to see if the issue is with the phone itself.
If the above steps do not resolve the issue, it may be necessary to seek the assistance of a professional technician or a vendor who specializes in NEC Infrontia PABX systems. They will be able to diagnose and resolve the problem.
2answers
How to assign trunk lines on NEC SL1000 Keyphone System?
Try posting here:
http://www.tek-tips.com/threadminder.cfm?pid=937&page=1
53helpful
2answers
1helpful
Headset for NEC Dterm80
Do a search for a plantronics headset. All of theirs work well with NEC
Wirless internet
we'll need a bit more information on the model number to help you out..
Sanyo Projector & NEC Note Book Incompatible.
You have to select I think it is function F8 or Function something to show or activate dual display function. Go to help menu in the computer and that may help you in this matter. Let me know if this helps. Thank you Jay
2answers
Need a manual for NEC ETW16DC-1 system
fonedud - The ETW model terminal will work on several NEC systems. Without knowing what system the telephone is connected to, it is impossible to address your concern. You should be able to find a local NEC Authorized dealer in your area to assist. djantz@necunifiedsolutions.com
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
