E&G Classics Pontiac G8 V6 Gt 2008-2009 Black Ice Grille And Rear Insert Kit Logo
G
Gerard Maheux Posted on Feb 05, 2014
Code p2097 check engine - E&G Classics Pontiac G8 V6 Gt 2008-2009 Black Ice Grille And Rear Insert Kit
  • Gerard Maheux
    Gerard Maheux Feb 05, 2014
    Hi Gerard Maheux, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
  • Gerard Maheux
    ungarage gm a tout verifier excepter le systeme dechappement
2015 Hyundai Sonata LF. Why 'check engine' light on with DTCs P2097 and P2196?
Fuel Air Ratio is incorrect due to failing sensors or broken exhaust. Sensor 1 bank 1 is actually the Fuel/Air Sensors not an O2 sensor. Your is reporting that the ratio is too rich so it is adding less fuel. Whilst this is good for fuel economy, it causes an overheat situation which can damage the piston or burn the valves. I had the same situation in my Lexus, but it was reporting too lean. After the fuel/air sensor was replaced, it reported too lean 100 yards down the road. I cleared that code and all was fine. The engine was burning off carbon die to the rich fuel situation. I recommend this, or a cheap scanner
www.fixd.com
P2097 OBD-II Trouble Code: Post Catalyst Fuel Trim System ...
https://www.yourmechanic.com > Articles
P2097 code definition P2097 is a general OBD-II diagnostic trouble code that indicates a fault with the post catalyst fuel trim system being too rich in bank 1.
P2196 OBD-II Trouble Code: O2 Sensor Signal Stuck Rich ...
P2196 trouble code definition O2 Sensor Signal Stuck Rich (Bank 1 Sensor 1) What the P2196 code means This code indicates there is too much fuel in the ...
2004 dodge grand caravan 3.8 code p2097
A good explanation of the code can be found on the link below...
https://www.obd-codes.com/p2097
It is probable the catalytic converter is no longer doing the job it is supposed to be doing but it is equally probable this has a deeper cause such as physical damage to the exhaust, too much unburned fuel entering the exhaust for too long due to a misfire, excessive engine oil consumption.
Considering the age of the vehicle it would be sensible to begin by ensuring the fuel pressures are ok and the injector spray patterns are good - bad spray patterns can introduce fuel into the cylinders that don't burn very well...
Vehicle CEL is on, various codes
P0300 is a random miss fire , a vacuum leak can cause this as well as low fuel pressure ! weak fuel pump , clogged fuel filter !
DTC P0171: Fuel Trim System Lean Bank 1
DTC P0174: Fuel Trim System Lean Bank 2 These two codes are saying the PCM - engine computer is see a lean condition .
DTC P0191: Fuel Rail Pressure (FRP) Sensor Performance
Circuit/System Description
The fuel pressure sensor is located on the fuel line. The fuel pressure sensor monitors the fuel pressure in the fuel line. The fuel pump flow control module (FPCM) monitors the voltage signal from the fuel pressure sensor.
You don't say what make , model an year vehicle ! These are for GM vehicles , yours could mean something else . Except the first three , those are genaric codes , same for all makes ! So can't say what this codes are P2097, and P2099 ! Can't mean this P2097 - Post Catalyst Fuel Trim System Too Rich Bank 1
P2099 - Post Catalyst Fuel Trim System Too Rich Bank 2
P1319 on extremely low tank
p1319 Land Rover:Misfire with Low/Empty FuelDrive cycle C:Signal out of range - above maximum
p2097
- Exhaust leak near O2 sensor
- Faulty O2 sensor
- Fuel contamination
based on these two codes it sounds like you have crap in your gas tank, especially water. Get two bottles of dry gas WITH fuelnjector cleaner. Add both bottles at the same time then fill the tank with PREMIUM ( not regular ) gas. MAKE SURE it is a good quality gas at a SUNOCO, MOBIL, etc station; not elcheapo.
If this doesn\'t clear it take it to a dealer.
Read more: http://engine-codes.com/p2097.html#ixzz363O1rCC1
Based on these two cod
1helpful
P2097 engine light on
P2097 code has two fault locations. 1) post catalytic converter fuel trim (FT), bank 1 - too rich. possible cause Catalytic converter. 2) Heated oxygen sensor (HO2S) 1,bank 1 range/ performance- circuit low. if it's running fine. probably just need to put an oxygen sensor in it.
P2097 & P0301
Code P2097 has to do with the performance of the down stream, O2 sensor (after the CAT). P0301 refers to a misfire detected on cylinder #1. Testing needs to be performed. Check oil quality and level. Does the car need an oil change. Poor oil quality can affect the VVT system. If I can be anymore help let me know. Please be as specific as possible. Good luck.
P2097 p2196 p2626
P2097 Post Catalyst Fuel Trim System Too Rich
P2196 O2 Sensor Signal Stuck Rich
P2626 O2 Sensor Pumping Current Trim Circuit/Open
yeah, you really have a bad O2 sensor
_________________careucar.com
2helpful
2answers
P2097 Error code in 2006 Dodge Grand Caravan, which O2 Sensor?
actually there are 4 sensors. one on each exhaust manifold and then as you said one prior and aft the catalytic convertor. this is saying it is reading too rich a reading. check the condition of your spark plugs. you need to pin point the reason. chances are it is not the o2 sensor. happy holidays
6helpful
I have a 2004 dodge caravan i get p0172 fault code
p0172 fuel system to rich , p2097 fuel mixture high downstream , p0480 cooling fan relay, hope this helps
Top E&G Classics Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you an E&G Classics Air Tool and Compressor Expert? Answer questions, earn points and help others
