GE Washing Machine WPRB9220COWW Error Code E43. What does error code refer to? No noticeable water laek, oil leak, or grease blow-off CSS stewgrp@starstream.net
SOURCE: machine fault code "f13"
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: Kenmore HE2T F20 plus Water leakage when tub starts to fill
Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require additional assistance, please let me know before rating the solution. I hope this helps you.
SOURCE: Error code E43 on display of WPRB9220DCC GE Washer
This is the beginning of a leaking seal in the gear box. Some units have a pan to catch the leak from getting to floor. Seal needs to be replaced, otherwise gearbox will fail (lot more $$$$)
