Passrord
SOURCE: CMOS Problem
The jumper is usually near to the CMOS chip, if you do not find the jumper, take out the motherboard coin battery for one minute, it does the same as the jumper.
SOURCE: Where is Cmos Clear jumper on motherboard to clear Bios password.
If you can't find the jumper, just remove the CMOS battery wait for 1/2 + hour and the re-insert the battery. This will reset the BIOS back to the default settings and you then need to set the Time & Date.
It may not remove the BIOS password if the laptop stores the password on an EEPROM chip.
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
