Washing Machines Logo
A
Anonymous Posted on Nov 04, 2013
Error code e16 - Electrolux Washing Machines
My hd decoder no 313941863145 is showing an error E52 searching 11170 MHz. Plse help me
Clearing DSTV E16 error via Internet
  1. Go to the Dstv Self service portal.
  2. Fill in your Smart card number, select the type of error you choose to clear "E16" in this case.
  3. Enter the captcha code then click "Clear Error" as seen in the screenshot below.
E16 ON DISPLAY FLASHING
The e16 error code indicates that there is a problem with the machines door lock.
What does e16 mean please?
An E16 error code means there is a heater insulation problem which could cause the tripping of your fuse box and other random cycle errors, but it's hard to prove without the replacement of your heater.
For more information on other error codes , watch this video .
http://www.espares.co.uk/advice/0/2531/how-to-understand-hoover-and-candy-washing-machine-error-codes
MY FRIGIDAIRE DRYER STOPS AND THE DISPLAY READS E16
I appreciate your post, Deejanae!
I see that your Frigidaire dryer is displaying an error code of "E16". It appears that "E16" is an invalid code. I would recommend performing a reset on your dryer and you can do that by flipping the household circuit breaker off for at least ten minutes. If you continue to experience an issue with an "E16" error code I would recommend contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Error code E16 on my bosch washing machine
Cause: Water inlet valve fault.
Action: Check inlet valve and water supply.
2answers
Error 19
Hi there-
Below are a list of the error codes for this model.
E16-E19 = Failed to scan head alignment sheet.
You can find this information at http://www.usa.canon.com/cusa/home
CANON MP140, MP145, MP150, MP160 RESET ERROR CODES
[Info140] pixel_trans.gif RESET ERROR CODES CANON MP140, MP145, MP150, MP160
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera
Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
2helpful
2answers
Canon mp250 error code e16
How to Reset waste ink counter (Error E16)
1. Unplug power and USB cable.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Hope it helps.
11helpful
3answers
Error E16 RISOGRAPH CR1610
E16 indicates a motor lock with the inking motor. Disassemble the ink pump unit and check for proper rotation of the inking motor itself. This error is caused by a current overload.
Also, remember to try powering on the machine while holding down the reset key to clear all error codes first.
1helpful
E16 error
Hi there.
E16 Error code means (on all canon compacts) that there is something wrong with the lens mechanism and it cannot contract/extract/focus etc. Basically, if the problem is not fixed by removing the batteries for 20 minutes and reinstalling them (make sure they are fully charged) then you'll have to take it into a shop or get a friend who knows a lot about this stuff to take it apart.
Good luck and thanks for using FixYa!!
6helpful
3answers
E16
press stop reset button for few seconds and you can use your black cartridge for printing,but do remember to put use black only setting in ur printer cartridge settings.
Top Electrolux Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
