Computers & Internet Logo
A
Anonymous Posted on Sep 10, 2013
Script error run preflight script for Rosetta Stone
4 Related Answers
Anonymous
  • 88 Answers
  • Posted on Sep 05, 2009
SOURCE: Help, I am trying to run Rosetta Stone Spanish. I
This error identify that the script for Spanish language is not installed or corrupted it comes in separate CD
Anonymous
  • 4 Answers
  • Posted on Jan 17, 2011
SOURCE: error 2123 appears when loading rosetta stone
I started getting "Error 2123" recently, and spent A LOT of time searching for the fix. Here is what finally worked:
Find the hidden file "tracking.db3". It's in the hidden folder "ProgramData/Rosetta Stone" under the "C:" directory. Copy and paste it to the Rosetta Stone install directory (Program Files/Rosetta Stone).
Error 2123 should be gone, but now there will be Error 2125. So, in the Rosetta Stone install directory, run the "service_installer" .exe file by double-clicking it.
leethedeuce
Lee A.
  • 4472 Answers
  • Posted on May 22, 2011
SOURCE: I am getting a Rosetta
First have you tried uninstalling it and reinstalling it and see if that helps the issue at all? Also is your OS up to date? Once I have more information I can assist you further.
Thank you,
Lee
Anonymous
  • 20 Answers
  • Posted on Feb 27, 2013
SOURCE: Rosetta stone on Mac doesn't open because of error 9120
Go to System Preferences (click on the apple in upper left corner of monitor and pull down)
Look for "hardware" and click on "sound". Is your mike on? Make sure your "output" level is high.
Hope it helps!
I got a Error 4118 with my Rosetta Stone program
Go to the Rosetta Stone website. They have some solutions posted for this problem.
Rosetta stone 9114 on mac
You get Error 9114 on Rosetta Stone if you have a bad disc or secutity settings. Find the fix at Questions Rosetta Stone Community
I have a Rosetta Stone V 3.4.5 and Win Xp. Rosetta Stone doesnt recognize the mic. What can I do to fix this error. The number of th error is 1117. My OS is Win Xp Waiting for help Alex
Create a security exception. 1. In ESET NOD32 (Smart Security 5), click Setup.
2. On the Setup screen, click Enter advanced setup... (bottom of screen).
3. On the Advanced setup screen, open Computer -> Antivirus and antispyware -> Exclusions.
4. Click Add , locate/select the Rosetta Stone Version 3 executable, then click OK. (In my case, the executable was in the C:\Program Files (x86)\Rosetta Stone Version 3 folder.)
5. Click OK on the Advanced setup screen.
Set the Rosetta Stone compatibility mode. 1. Right click the Rosetta Stone desktop icon or Start -> All programs -> Rosetta Stone.
2. Select Properties from the list.
3. Select the Compatibility tab.
4. Check the Run this program in compatibility mode box.
5. In the list below the check box, select the OS (in my case, Windows 7).
6. Click OK.
16helpful
2answers
Error 2123 appears when loading rosetta stone
9helpful
3answers
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Hello my friend.Usually this error is cause because antivirus is blocking that program and usually bitdefender.So
1.Open BitDefender Antivirus in Expert Mode,
2.Click on the Antivirus tab
3.Under the Shield tab click on the Advanced Settings button.
BitDefender Active Virus Control Settings window should be displayed
4.Now add an exclusion for Rosetta Stone(click on + and find your program and click ok)
If you don't have bitdefender add an exclusion like we did with bitdefender for your rosetta stone
1helpful
2answers
After uploading the application software for Rosetta Stone, I try and start the application and I receive: there was an error in the application. error 2123. How do I fix this problem for my iBook G4...
1helpful
2answers
There is an error with this application
2helpful
286helpful
21answers
Rosetta Stone error 2123
1.)Open BitDefender Antivirus in Expert Mode,
2.)click on the Antivirus module
3.)under the Shield tab click on the Advanced Settings button.
(BitDefender Active Virus Control Settings window should be displayed)
4.)adding an exclusion for Rosetta Stone solved the problem
or
If you have any other antivirus software
adding an exclusion for Rosetta Stone solved the problem.
Top Rosetta Stone Computers & Internet Experts
vince
Anonymous
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Rosetta Stone Computer and Internet Expert? Answer questions, earn points and help others
