When i started to formate my pc and install windows 8 suddemly for shortage of charge my laptop turns off now opertaing system is not detecing how can i boot it up again or install windows 8 on it?
SOURCE: installation problem on Toshiba Satellite M205-s4804
Can you provide a little more info? In the mean time, you might consider browsing LaptopExperts.net to see if anyone else has had a similar issue, you can use their advice as a guide.
-TRT
SOURCE: hp laptop has failed to start windows
There is some debug disks out there for download try running one of them. you must follow the instructions carefully!!! if that dosent work you may just need a new hdd. you should be able to get it from here.... http://www.fdisk.com/fdisk/HardDrive.htm
SOURCE: Laptop wont boot on, it starts but turns off again
I'm guessing ou have windows XP?
if so you hae a corrupted regisry and need to boot from your Windows CD and at he first et of questions choose Eneter to intall windows, then F8 to continue and then it should tell yo another Windows insatallation has been found and ask if you wish to perform an automatic repair.
Give it a try and enjoy :)
Testimonial: "Thanks much, will try that."
SOURCE: I have toshiba L300 pc laptop, i tried to formati
kindly follow these steps:
Hope this helps. Please rate my response.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
copy c:\windows\system32\config\system c:\windows\tmp\system.bak
copy c:\windows\system32\config\software c:\windows\tmp\software.bak
copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
copy c:\windows\system32\config\security c:\windows\tmp\security.bak
copy c:\windows\system32\config\default c:\windows\tmp\default.bak
delete c:\windows\system32\config\system
delete c:\windows\system32\config\software
delete c:\windows\system32\config\sam
delete c:\windows\system32\config\security
delete c:\windows\system32\config\default
copy c:\windows\repair\system c:\windows\system32\config\system
copy c:\windows\repair\software c:\windows\system32\config\software
copy c:\windows\repair\sam c:\windows\system32\config\sam
copy c:\windows\repair\security c:\windows\system32\config\security
copy c:\windows\repair\default c:\windows\system32\config\default
Thanks.
Have a good day.
SOURCE: i have accer aspire 5920 laptop...it have booting
First how old is your LP? and 2nd try replacing the BIOS battery inside the PC wait 24 hrs then install the new battery, this might help?
